mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
So I thought I would have a look at my drive shaft bearing today. Been a few yrs since dealer replaced it (probably only 1000 - 1500 kms on it).
Took off secondary
Took off left plastic lower shroud
Unbolted my after market belt guard (Nitros223 guard)
PB blasted the two set screws on back side of bearing, and was able to take them out.
I was finally able to pull out the bearing and the bearing plate w little trouble. Lowered my sled and supported the drive shaft.
I'm going to replace the bearing as it's a little rough...and although it did have grease inside, it also had some rust.
So a few questions...
1..This bearing has a totally different seal than the jackshaft bearing which I easily pryed off and regreased. I actually ruined the drive shaft seal with my pick, so I could get at the bearings. Is this driveshaft bearing normally more difficult to get the seal off than compared to the jackshaft seal?
2...Driveshaft bearing has an attached collar that the set screws go into. This is part of the bearing..correct? So the new bearing will have that same collar?
3.. After I unbolted my driveshaft bearing housing...the 6 bolt holes no longer allign perfectly with their bolt holes into the side of the motor housing. How do I get those holes alligned when I put everything back together...??
Thanks all
Took off secondary
Thanks all
Thanks all
1) Some seals just are tighter then others.. it happens. Are you talking the chain case side lower?
2) Is this on the lower drive shaft speedo side? Yes they have a color on the inner race with 2 set screws. Save the set screws as most of the replacements dont have the set screws.
3)Are you talking the lower dirve shaft on the chain case side? There is an 0 ring right? Can you post some pictures so I can see what your asking?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Loosen up your track to take tension off the driveshaft. That should help you get your bearing housing bolts in.
mp5
- Feb 14, 2011
- 09 Nytro XTX
Mr Sled...I am referring to the driveshaft bearing on the clutch side. It's the bearing behind the speedo...attached to the drive shaft.
It has a totally different seal than the clutch side jackshaft bearing. I was able to take that seal off w no problem and clean/regrease it.
My cell won't load my pics...says the file is too big
mp5
- Feb 14, 2011
- 09 Nytro XTX
Perfect...thanks man.
Got it. Yes that bearing has a collar with 2 set screws. Also you can pull both seals just be more careful on the collar side. As far as cell phone images, yes they are usually huge and will need to be reduced. I added an image resizer app. Mush easier to load images for web.
mp5
- Feb 14, 2011
- 09 Nytro XTX
mp5
- Feb 14, 2011
- 09 Nytro XTX
mp5
- Feb 14, 2011
- 09 Nytro XTX
Does anyone happen to know the p/n for this speedo bearing on the clutch side?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
93306-20589 should do the trick.
I have noticed on some replacement speedo bearings (drive shaft - clutch side) that the seal is not intended to be removed without seriously compromising it. It contains a very rigid metal seal coated in rubber.
MS
MS
mp5
- Feb 14, 2011
- 09 Nytro XTX
MS
Yesss.....what a pita. I was fully hoping to just pop that off, wd40 it, dry and repack it. But instead I compromised the seal and ended up learning how to take out the whole bearing. Glad I did though...now I know how and won't be as big a deal next time.
Oh and thanks for the p/n man.
I searched all through my service manual for that part and could not find it. It wasn't in the track section or the engine section....
Dr. FeeLGooD
[I searched all through my service manual for that part and could not find it. It wasn't in the track section or the engine section..]
I am guessing you haven't noticed the parts finder button on the top right corner of this page.
mp5
- Feb 14, 2011
- 09 Nytro XTX
Lol....do now. I usually just go online for p/n's but was un the shop late last night w my serv manual. I was determined to find it in there...lol
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Just an F.Y.I if you crop the picture it will let you upload it.
mp5
- Feb 14, 2011
- 09 Nytro XTX
Yeah...that's what I ended up doing, which is why only a portion of the pics are showing lol. Been a while since I've posted pics on TY and couldn't figure out why they weren't uploading.
Picking up new bearings tomorrow.
