Ricky Prewitt
- Dec 19, 2016
- Richmond
- 2017 Yamaha sidewinder LTX SE
Does anyone have the Evolution powersports stage 3 tune in? Wondering how it is doing. Have herd about TD but not EVP .
I've ran stage 3 and now run stage 4. Both ran flawlessly.
Ricky Prewitt
- Dec 19, 2016
- Richmond
Right on man what else do you have with it? What muffler .. clutching ?I've ran stage 3 and now run stage 4. Both ran flawlessly.
I'm running Hindle muffler and Ulmer Clutching now.
WINDER1987
I'd love to but am so scared with no warranty lol
- Apr 14, 2003
- Hessel, Michigan
I can tell you that all the stages work great from EVP and 634 trouble free miles and you want power? Stage 3 for trail use with Premium fuel.
Stage 4 is 50/50 race fuel and premium.... HANG ON!!!!
Ricky Prewitt
- Dec 19, 2016
- Richmond
WhT do you run for clutching ? Just weights with spring adjustments? Stock belt?I can tell you that all the stages work great from EVP and 634 trouble free miles and you want power? Stage 3 for trail use with Premium fuel.
- Apr 14, 2003
- Hessel, Michigan
Thunder Products kit for the sidewinder
Weights, primary spring and glide washers. Secondary stays the same. 8JP stock belt with good luck so far.
Started with stage 3 worked great and now on to Stage 4 on 91 pump as they have reduced boost from 16# to 14.8# have ran stage 4 for 400 miles so far and works great.
Ricky Prewitt
- Dec 19, 2016
- Richmond
Wonder why they turned the boost down? Maybe because 95 is hard to find at stations ? Wonder how that effects the HP ? They were claiming 71 hp gain with stage 4Started with stage 3 worked great and now on to Stage 4 on 91 pump as they have reduced boost from 16# to 14.8# have ran stage 4 for 400 miles so far and works great.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
- stage 0 – Fuel correction for running an aftermarket exhaust
- Stage 1 – 12.5 lbs boost +22 hp over stock
- Stage 2 – 12.5 lbs of boost +37 hp over stock – 91 octane (dyno video)
- Stage 3 – 14 lbs of boost + 51 hp over stock – 91 octane
- Stage 4 – 14.8 lbs of boost + 58 hp over stock – 91 octane
- Stage 5i – 17 lbs boost, big injector +79 hp over stock
- Stage 1Ri – 13 lbs boost, big injectors, replacement wastegate actuator + 43 hp over stock
- Stage 2Ri – 15 lbs boost, big injectors, replacement wastegate actuator + 68 hp over stock
- Stage 3Ri – 18 lbs boost, big injectors, replacement wastegate actuator + 85 hp over stock
- Stage 4Ri – 21 lbs boost, big injectors, replacement wastegate actuator (in development)
- Stage 5Ri – 25 lbs boost, big injectors, replacement wastegate actuator (in development)
- Stage 6 – Big Chute/Holeshot direct replacement turbocharger upgrade – up to 40 lbs of boost! (in development)
Ricky Prewitt
- Dec 19, 2016
- Richmond
Ah they updated nice
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi stone,how pricy was there complete set up,pipe stage 3 or 4 and clutching,i am somewhat confused on the usa conversion,i guess its .74 Canadian to one dollar USA currency,so what will it cost me in US funds?Started with stage 3 worked great and now on to Stage 4 on 91 pump as they have reduced boost from 16# to 14.8# have ran stage 4 for 400 miles so far and works great.
- Apr 14, 2003
- Hessel, Michigan
I think it has more to due with maxing out the duty cycle of the injectors. They likely found afr on the lean side at anything above 15 psi.
Testing Stage 4 we found out the stock injectors were maxed out at 16psi.
- 11K
