Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Just added the linq system purchased from up north tech. Nice product and perfect fit! I also added the do 3 gal gas can. Fits nice behind the large bag. only issue is the can will have to be removed to access the bag. I am hoping that I won't need the extra fuel unless heading out into the back country!
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Sweet....cost?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Nice
Ken at UNT makes great stuff
For the Indy and mxz 129’s he makes a plate that creates 2 linq positions. Really well thought out and creates a ton of options
Ms
Ms
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Side, cost was 159 for bracket and 139 for the can.
SideHogger
- Apr 16, 2016
- upstate ny
Thanks...retired and on fixed budget now ...lol...so every penny counts and that seems like a very fair price.Side, cost was 159 for bracket and 139 for the can.
PowderFalcon
Pinnin' it!
No concern with the weight of the fuel being on the back of the tunnel ? Is there potential to damage tunnel with the added weight?
VyperNation
- Feb 4, 2018
- MI
- 21 Winder XTX LE 146
18 Winder XTX SE 137
--past sleds--
18 Viper LTX DX
(2) 06 Apex RTXs
99 Vmax 500
I would HIGHLY recommend the BOP rear tunnel savers for anyone carrying weight on the back. I just put them on my new 146, and I don't even plan to carry weight...No concern with the weight of the fuel being on the back of the tunnel ? Is there potential to damage tunnel with the added weight?
https://www.barnofparts.com/rear-tunnel-savers
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I can fix you up with a mounting plate and fuel caddy for less if you need something.
My plates are $95. Plate also allow use of rotopax set up. A 2.5 caddy and mount would run you $108.
Hoosiersnow
Is the smallest rotopax 1.5 gallons? I have a cat 2 stroke but find this is the best forum to get info from. I'm looking for a solution to carry oil - which most of you don't think about I'm assuming Doo has that container but it's pricey once you factor in the mounts.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
I put the linq adaptors on the back of my 129 with a White Out Technologies plate, and put the 1 gallon - 3.8 l rotopax.
The White Out or UNT would work fine to mount to.
Ski doo has smaller linq gas and oil (5l) cans now but they are pricey.
MS
MS
Capt Yamaha
Is your winder the 137”? I have a 2021 LTX GT 137” with the std large bag. What are the part #s? ThanksJust added the linq system purchased from up north tech. Nice product and perfect fit! I also added the do 3 gal gas can. Fits nice behind the large bag. only issue is the can will have to be removed to access the bag. I am hoping that I won't need the extra fuel unless heading out into the back country!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Yes Bluebullet is a 137” sidewinder gt. Also the factory bag that comes with these sleds is the medium bag which is on his sled with the linq tank.Is your winder the 137”? I have a 2021 LTX GT 137” with the std large bag. What are the part #s? Thanks
WinderFab
- Mar 1, 2009
- Woodbridge, ON
This is another option from kimpex, I decided to go this route just because I don’t really need to carry 12 extra litres of fuel around plus you can also use there travel bag with the tank or the travel bag alone without the rotopax. Pics below are with the 6L rotopax
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
I used to carry the 1.5 gallon ropex on my apex, I had hoped I could use it on my SW but with the extra factory bag won't fit. I may try the stackable bag option and remove the lage factory bag and install stackable with fuel closer to seat..... Thanks
SideHogger
- Apr 16, 2016
- upstate ny
Bluebullet, is that the large bag or the medium size bag?Just added the linq system purchased from up north tech. Nice product and perfect fit! I also added the do 3 gal gas can. Fits nice behind the large bag. only issue is the can will have to be removed to access the bag. I am hoping that I won't need the extra fuel unless heading out into the back country!
- 10K
