Hi guys going to do a 998 Build again (2023 SRX) with closed loop!!! So awesome and I want max power on pump gas! Are all the tunes pretty even from TD, Hurricane & Precision EFI. I really would like to stick with one company. What's max HP you guys are seeing on 93 and all the bolt ons (quite Muffler) including the header and possibly adding Boostane that's working so well on my 850 Boost.
Thanks Skydog.
Thanks Skydog.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Sent you a PM.
number1kyster
Most guys are going to tell you the tune they run is the best. Most have not tried multiple companies. I have not heard anything bad in the 998 world in regards to TD or Hurricane. I ran TD, but I would not hesitate to run Hurricane if I buy another 998T. I’ve heard Dave has excellent customer service.
sledding rocks
u wont go wrong on your choice , there all good
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
I Refer to boost mostly as HP who knows? With good 93 and boostane you can run 20lbs of boost, I wouldn’t run it 3 miles down the lake WOT but if you are sensible it will work. With the header you won’t see much more than 18lbs unless you go with the upgraded waistgate the venders offer.Hi guys going to do a 998 Build again (2023 SRX) with closed loop!!! So awesome and I want max power on pump gas! Are all the tunes pretty even from TD, Hurricane & Precision EFI. I really would like to stick with one company. What's max HP you guys are seeing on 93 and all the bolt ons (quite Muffler) including the header and possibly adding Boostane that's working so well on my 850 Boost.
Thanks Skydog.
Thanks for info guys!
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
X2 300hp is very doable. But it's going to take Bob's list to get it done right. .02¢We are definitely very spoiled with the vendors that supply the tunes for our sleds. I can only speak of my experience with my Hurricane tuned SW.
The only issue I have with TD is they offer so many tunes it confuses me.
I started out with Hurricanes SS stock and performance muffler tunes and have ended up with Hurricane's:
-extra clearance header
-high output fuel pump
-header tune bundle 240/270/300
-closed loop
-data logging
I have added:
-3" TD stock mod muffler
-adjustable fuel pressure regulator
-Gap ram air intake
So long story short...my sled has performed flawlessly on the 300 Header tune with reliable, fuel efficient power. I have been readily able to talk to Dave from hurricane for advice and Mike Knapp has also been up to speed on the Hurricane products analyzing my data logs ect that has helped me as well.
I think Hurricane now offers a 310hp trail tune now as well.
IMO...you can't go wrong
JM experience
sideshowBob
On my sled, I feel my sled is exceeding the vendors 300hp by a fair bit. I have had to up my fuel pressure a significant amount to help the closed loop attain the tunes target AFR.X2 300hp is very doable. But it's going to take Bob's list to get it done right. .02¢
In the last couple seasons my sled has won numerous local snow drags competing against sleds with supposedly much higher hp numbers.
I will say it again...you cant go wrong with Hurricane or TD but TDs numerous tune offers confuse me??
Doc Harley
- Oct 17, 2016
- Here & there
I'm sure...I've seen your mph @ distance. Like a jet.On my sled, I feel my sled is exceeding the vendors 300hp by a fair bit. I have had to up my fuel pressure a significant amount to help the closed loop attain the tunes target AFR.
So awesomeWe are definitely very spoiled with the vendors that supply the tunes for our sleds. I can only speak of my experience with my Hurricane tuned SW.
-closed loop
-data logging
I have added:
-Gap ram air intake
JM experience
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Precision EFI Stage 4, best quality parts out there. Ask @Turboflash about his!
Doc Harley
- Oct 17, 2016
- Here & there
Pefi, is ridiculous. Build quality is second to none, in this industry.Precision EFI Stage 4, best quality parts out there. Ask @Turboflash about his!
He's definitely on a different level.
With that said, I use Turbo Dynamics.I have zero reason to dissuade you from the truth. No problem with TD
Trailleader
My 17 is a pefi stage 4
It’s nice stuff
It’s nice stuff
JLR
- Dec 6, 2006
- Winnipeg, Mb
- 2011 apex mcx 290, 2018 sidewinder xtx se 137 precision stage 4, 2020 Sidewinder Srx
stage 4 pefi is good
