Viper190MCX
- Sep 11, 2015
- Telemark
- Norway
- 2016 Yamaha Viper MTX 153 MCX-270
I am thinking about changing the header on my 16 Viper MTX with MCX-270 kit.
Does anybody here have any experience with this and is there any gains? (Straighline/Ulmer or the MCX header f.ex)
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
There's a few post about this topic on here recently.
I just bought the Ulmer header. It's kinda the next step for me. Expensive mod though.
Yamadog
I am running the Ulmer/SL header in my 15 and mage so many changes not sure what hp came from where but it is amazing
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
Same here AWESOME.....
northof50
- Dec 30, 2013
- Northern ,mb
- 14 viper LTX Deluxe
alexm2816
- Mar 28, 2016
- SE Wisconsin
- 2016 SR Viper LTX-DX Turbo
I bought MBRP header it does not fit. I emailed them, we will see if they make it right.
I can't fine the specific post at the moment... but Mr. Ulmer had run the MBRP header on the dyno and noted no meaningful power gains across the power band. The Straightline can be had for $550 if you know where to look and it seems to be the consensus as the header to use power gains as well as for fit and finish as well.
Obviously this is all second hand and may require more digging or a comment from someone more knowledgeable.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
You may or not have gains with a new header, but you absolutely need it. You will crack the stock header fairly quickly with the mcx 270 kit. 3 of my buddies have higher boost vipers and they all cracked stock headers last season.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Any luck with this problem?I bought MBRP header it does not fit. I emailed them, we will see if they make it right.
northof50
- Dec 30, 2013
- Northern ,mb
No I will stick with stock.Any luck with this problem?
northof50
- Dec 30, 2013
- Northern ,mb
The reason I went to this was to handle 10psi boostYou may or not have gains with a new header, but you absolutely need it. You will crack the stock header fairly quickly with the mcx 270 kit. 3 of my buddies have higher boost vipers and they all cracked stock headers last season.
michael maher
- Mar 23, 2015
- New Jersey
- 2008 Yamaha Vector
subscribing
