Fleecer
- Jun 13, 2014
- 2019 SRX
Does anyone know the Arctic Cat Heated Seat Kit Part # that will fit and can be installed on a Sidewinder? I'm looking for complete kit to install on LTX SE:. Heated pad, switch, harness etc.
kalakauppias
- Dec 21, 2010
Arctic Cat Heated Seat Kit - 2018-2019 ZR XF 3000 7000 9000
Arctic Cat Heated Seat Kit - 2018-2019 ZR XF 3000 7000 9000 - 7639-965
www.countrycat.com
KillerBee
- Jan 1, 2010
- Waukesha WI
- 2018 Sidewinder LTX LE 50th
I suggest you do a search about seat heaters. The arctic cat ones are plagued with broken wires after very little use. The consensus appears to be to go with aftermarket.
Fleecer
- Jun 13, 2014
- 2019 SRX
Arctic Cat Heated Seat Kit - 2018-2019 ZR XF 3000 7000 9000 - 7639-965www.countrycat.com
Thanks for the link! The description says seat kit, however the pic only shows the heated pad.
Will the kit include harness, switch and everything to make it work? Just want to verify before I pull the trigger.
earthling
If you look at the 'more info' link there are installation instructions. In the instructions it gives the kit contents as;
Kit includes:
p/n QTY DESCRIPTION
0123-788 5 Cable Tie
0609-025 1 Heated Seat Switch
0609-913 1 Seat Heater Pad
1686-766 1 Harness *
1686-867 1 Harness **
2653-149 1 Instructions
That heater/switch is used on many kits, the only difference is probably the harness(S).
Kit includes:
p/n QTY DESCRIPTION
Fleecer
- Jun 13, 2014
- 2019 SRX
Escape
- Apr 20, 2016
- Buffalo, NY
- 2022 Yamaha Sidewinder LTX GT (zero miles !!)
- Western New York
I had 3 heated seats on 2016 Yamaha STX DX replaced under warranty.. cables and connectors failed every time
Weslemkoon
- Sep 30, 2021
- ONTARIO
- 2022 Sidewinder Ltx GT PS
Had a heated seat on my 2012 xf1100 turbo. It was the only thing that didn't break.I had 3 heated seats on 2016 Yamaha STX DX replaced under warranty.. cables and connectors failed every time
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
I took my seat cover off to see if mine could be repaired. They place a hard plastic tube over the wires and because of the seat movement the tube cut 2 of the wires. I cut all wires, removed the tube from the harness, soldered wires with individual heat shrink, taped them all up and recovered the seat. I reused the staples and placed each staple into the original holes in the cover and plastic. You wouldn't know it was ever uncovered. i will see how long it holds up, but for now it is working. I would remove the plastic tube before installing a new kit.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
I absolutely love the heated seat….especially in those -10 degree days! So glad I put one on.
