Garceau
Had to get a new user name
Been reading through a pile of threads all morning looking for the answer
07 Apex 2200 miles
I haven't driven this particular sled in about 8 years.
Swapped out the gas. Replaced the battery this morning
No fuel pump hum.
Can hear relay click, can feel relay click. Took it out and swapped it with the other 2 which are the same and still no activation of the pump.
I've traced every wire I can and nothing noticeable as far as chewed threw wires etc.
I've checked every fuse I can find with ohm meter and all showing good.
Sled turns over just fine of course. But no fuel.
I know it could be a plethora of issues.
But any other leads for me to track down?
Obviously could be bad pump. Still looking into that.
07 Apex 2200 miles
No fuel pump hum.
And if you don't have power after Steiners test, go to the fuse circuit at the starter relay. That is where power for the fuel circuit comes from.
Any numbers showing on the dash?
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Pull all the fuses and check for corrosion and green crud. Pull the connector at the starter solenoid and check that too.
sideshowBob
Sitting 8 years...fuel pump could be gummed up and need replacement. I would provide power directly to the pump and see if it runs.
