x2thez
- Mar 29, 2005
- Buffalo, NY
- 2014 Yamaha Viper LTX
2009 Yamaha Vector LTX
1987 Yamaha Bravo
Ok, I recently installed some snow trackers on my 09 Vector LTX. I noticed that it is a little squirrley at times in the deeper snow. I did some searching around here and alot of people said to make your front A arms level.
I went to do this, and since I dont have a GYTR shocks, it seems to me like they are longer perhaps? If I was to make the sled level, I would have about 1/2" of play in the spring so I am just wondering if there is something else I am missing on this?
Thanks, PS< mods if you have to move I understand, but I figured this was something that would apply to any newer yamaha that doesnt have the clicker shocks or floats.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
x2thez said:Ok, I recently installed some snow trackers on my 09 Vector LTX. I noticed that it is a little squirrley at times in the deeper snow. I did some searching around here and alot of people said to make your front A arms level.
Raise the machine up then loosen the jam washers until you can slightly spin the springs on the shox, give each about a 1/4 turn then use to jam washer to secure the collar and you should be good to go.
On my Vector, with GYTR's, I can't the A arms exactly level either but they are as low as they can go so that is the best I can get.
YukonMP
- Dec 25, 2014
- Yukon Territory
Is this idea of getting the A-arms level kind of a rule of thumb in good sled setup?
Yes. As in the instructions from Snowtracker. Zero front shock preload, limiter strap in factory position and toe at 0.Is this idea of getting the A-arms level kind of a rule of thumb in good sled setup?
In deep snow the Snowtrackers are not doing much just like any other carbide. Not sure why they would make the sled squirrely when they don't have traction.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Agreed.
Check your toe .
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
Toe-in makes your sled squirrely. If you set your toe to (0) your going to get a toe-in condition occasionally because of the slop in your steering system. To overcome this when setting your toe, pull ski tips together and keep them together with a bungee and then set your toe to (0). By doing this you eliminate the possibility of the skis to become toed-in because of the slop in you steering system.
superfan75
That's a good tip. I never thought of that when I set my toe.Toe-in makes your sled squirrely. If you set your toe to (0) your joining to get a toe-in condition occasionally because of the slop in your steering system. To overcome this when setting your toe, pull ski tips together and keep them together with a bungee and then set your toe to (0). By doing this you eliminate the possibility of the skis to become toed-in because of the slop in you steering system.
BryKlu
- Nov 1, 2017
- Presque Isle, Wisconsin
- 2010 Vector LTX GT
Even with studs leave the limiter strap in the factory position?
Yup. Ran with 108 up the middle on my Attak . Limiter strap in the stock position. Works awesome
BryKlu
- Nov 1, 2017
Great! I have to drop some aggressives on this weekend. Doesn't seem to stop snowing here in Presque Isle
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I feel as though the Trackers vastly improved loose or deeper snow handling.
Definitely 0 tow.
whitedust1
My STs give me good steering in both deep snow and hard pak set up to ST instructions. However I did did leave my Bergstom shims in the Apex xtx ski boots....figured shims couldn't hurt. Many said don't shim STs but I did anyway and works super well. You might want to try shims to level out the skis a bit more worked for me.
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Just a tip, when setting toe in Do Not have your skis in the air. I made that mistake on my grand daughters Phazer and it was so squirrely she couldn't drive it. Set your toe in at 0 to 1/8 " out with weight on skis and everything will work as advertised.
Winderallday!
In addition to Handy's tip above, I recommend lifting the front end off the floor between measurements/adjustments to let the steering find it's new home, then lower sled to ground and perform measurements to get as close to zero as you can using lightly loaded bungee to pull ski tips together to take up any steering slack. I found that on concrete garage floor the carbides can dig in and give you inaccurate measurements. I used a left over piece of plastic trailer ski guide under each carbide to allow them to slip on floor rather than scrub the concrete.
