Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I ram them for 3 seasons on my ZR9. They worked very well. Used them until I switched everything to QS3's.
Oh. One in Pic is not done.You did mine last fall and installed the new caps.
I dropped them off on the way to the Milwaukee snow show. All 4 shocks..
The clickers still work fine.
This pic. Confused me
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
That pic was posted last winter.
So are you bottoming on 1,2 and 3?That pic was posted last winter.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Bottoming on 1 and 2 in the rough and big rollers on the trails we have now.
I tried 3 and it is so stiff I almost bounced my head off the handles bars.
On the rear I run set on 3 with the torsion springs on medium and center shock with 160/260 with about 1.5 turns of preload.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
The hygear twisted spring setup has softer front springs than stock. I am going to put the stock springs in it in place of the main spring and try it this weekend.
Where you headed? Will be riding out of Baraga Sat and Sunday.The hygear twisted spring setup has softer front springs than stock. I am going to put the stock springs in it in place of the main spring and try it this weekend.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Munising area
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
What is the part number on the main spring, I can only see part of it? You should be somewhere 150-175lbs/in for spring rate depending on your weight.This pic. Confused me
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
150 main and 400 on tender spring
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
BADSLED
- May 13, 2004
- Syracuse, NY
2011 Apex SE
Looks like you are sprung on the lighter side. Right now your combined rate is 109lbs/in and probably need to use 185lbs/in main spring for combined rate of 126lbs/inch if you're a bigger guy.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
220lbs in my birthday suit.
I gave hygear all my information when I ordered them and this is what they sent me.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
That's not fully correct.... only part of it. The effective spring rate that @1nc 2000 has is 109/150 lb/in which is just a little firmer than the stock SRX front springs. Remember, those are DUAL RATE springs from Hygear.Looks like you are sprung on the lighter side. Right now your combined rate is 109lbs/in and probably need to use 185lbs/in main spring for combined rate of 126lbs/inch if you're a bigger guy.
For comparison, the stock springs on the SE shocks are 120 lb/in rate. The SRX springs are 90/145 lb/in rate.
If you wanted a triple-rate setup with a little firmer final rate you could achieve the following:
300-lb top spring, 400-lb middle spring, 175-lb main spring= 87/109/175 lb/in rate
300-lb top spring, 500-lb middle spring, 175-lb main spring= 91/129/175 lb/in rate
400-lb top spring, 500-lb middle spring, 175-lb main spring= 98/129/175 ib/in rate
