CaptCaper
- Jan 1, 2007
- Northern N.H.
It went fine with skid in and by myself. Hygear did a spot on job of specking out the size spring for me. Rides nice.. now I have less sag then with the Upgraded XTX shock that I had done. I now am carrying some extra tools thus adding weight. I always needed a big boy spring on my Attaks it seems.
Simple to do with typical tools and some cleaver improvising. The trickiest part was getting the step drill to drill the bracket required to do. I used ratchet extension and drill adapter any home probably has and fished my way behind the wheel and in front of the mount arm to get a straight shot thru the bracket.
Remove upper shock bolt,brackets first.. then reverse to install or you may not get the front bolts in without fighting it.
