glenngy
Hi all have a 2017 sidewinder, overheat light came on and she started to bog, not sure why was really cold out but the last 3/4 mile home had low snow, scratchers wernt making contact so... i shut er down asap waited 15 min after putting snow under tunnel, fired up np, temp was down a bit light off, got only cpl hundred yards and light comes on so shut er down waited 20 and drove her home, today fire it up, idles at 1400 so took it into the field gave a squeeze, mint! let off throtle falls to 1400 and stumbles, I changed scratchers added water wetter heat was fine for the 45 mins i ran it, squeeze the gas runs smooth and fast (270hp hurricane) stop idle drops 1400-1450 and kinda stumbles or pops, any help would be great. no smell, no codes on dash. TIA
sideshowBob
Did it throw any codes?
It may just be a coincidence that the low idle showed up after the overheat but things to check:
-anti freeze at a normal level?
-any anti freeze in oil? this usually shows up with decreasing antifreeze level and increasing oil quantity
Most common things to check:
-needs new plugs...change them
-plugged or dirty air filter
-vacuum line off
-boost tube split or leaking or clamp loose
-cracked or loose pipe from exhaust manifold to turbo
-vacuum line off
glenngy
antifreeze level good, just going to change plugs now, no codes, Thnks 4 the feedback !Did it throw any codes?
-vacuum line off
sideshowBob
Hopefully just something simple....could just be really poor fuel as well.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
My heat exchangers iced up a couple seasons ago. Same thing, lite came on, etc. I honestly thought something bad happened. Ran funny, like yours. Checked compression, new plugs. The next time I went to ride it, it ran flawless.
Can't explain, other than, I know what you're going through.
glenngy
new fuel 5 gallons 91 and octane boost. thanks man !Hopefully just something simple....could just be really poor fuel as well.
glenngy
thnx 4 the feedbackMy heat exchangers iced up a couple seasons ago. Same thing, lite came on, etc. I honestly thought something bad happened. Ran funny, like yours. Checked compression, new plugs. The next time I went to ride it, it ran flawless.
glenngy
So changed out coolant, swapped out plugs, washed air filter and reset ecu, running back to normal. Thanks for all the advice.
Doc Harley
- Oct 17, 2016
- Here & there
No more worries....good to hear.So changed out coolant, swapped out plugs, washed air filter and reset ecu, running back to normal. Thanks for all the advice.
sideshowBob
Great!So changed out coolant, swapped out plugs, washed air filter and reset ecu, running back to normal. Thanks for all the advice.
Just a word of caution if you have drained and filled coolant these sleds are very difficult to bleed the cooling system to ensure there is no air in the system. Use the search function to get info on effective techniques.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Short answer for "no need to bleed". Get something like this: It vacuums out the air and sucks new coolant into the system.Great!
