Have anyone run a gt turbo with a oil restrictor on a apex turbo with the mcx return pump? Since you block off the stator cooling with the mcx bolt and now the cooling is going thru the turbo. Will the oil flow be enough with the 1mm restrictor to do the cooling job?
