SMOKNZ
I covered holes in the bottom, as well as moved the clips 2 slots up (one slot up from stock) and the bog is still there.
fixerman519
Did the air box mod and i am extremely happy!!!, I am running a 03 RX, swapped to 165 mains, runs awesome , having rpm issues (which I had before) , so I removed the rivets from tips for now and am really close on RPM, I can stay with and almost pass the Apex's we were running with (top end), and throttle response was excellent with stock carb springs, thanks for tip.
Sled Dog
SMOKNZ said:I covered holes in the bottom, as well as moved the clips 2 slots up (one slot up from stock) and the bog is still there.
I think you are going to have to clean your carbs again bud there are too many running this mod without that problem soak the carb over night and blow air in every nook and cranny make sure you dont have any jets mixed up like the power jets into the main. If you can get some Mechanic in a bottle and run a full 4 oz can in a full tank to help with the cleaning as well. It could also be your plugs.
Sled Dog
Well I decided to open up my baffle some more not the bottom. I drilled another eight 1 1/8 holes in the baffle and went for a two hour ride and it has made a noticeable difference running really strong now more than before for sure. I have not had a chance to check my plugs yet will post back with some pictures once I check out the plugs. Oh yea it looks like my RPM went up another one hundred.
stomper
fixerman519 said:Did the air box mod and i am extremely happy!!!, I am running a 03 RX, swapped to 165 mains, runs awesome , having rpm issues (which I had before) , so I removed the rivets from tips for now and am really close on RPM, I can stay with and almost pass the Apex's we were running with (top end), and throttle response was excellent with stock carb springs, thanks for tip.
What exactly are you running for clutching. Is it the stock 03, primary and secondary, with the one rivet removed on the weights of the primary.
stomper
Sled Dog said:Well I decided to open up my baffle some more not the bottom. I drilled another eight 1 1/8 holes in the baffle and went for a two hour ride and it has made a noticeable difference running really strong now more than before for sure. I have not had a chance to check my plugs yet will post back with some pictures once I check out the plugs. Oh yea it looks like my RPM went up another one hundred.
What made you decide to open it up more.
Sled Dog
My plugs were running a dark reddish brown so I decided it needed more air. Will be interesting to see what color they are now. It sure seems to have woke it up a bit more and I gained 100 rpm.
Sled Dog
The plug color is awesome much much better it is now light brown to gray. Trying to post a picture but is too big.
I'm thinking of modding the airbox of my 05 Warrior. It looks like most people are messing with their jetting though when doing this? Is there any performance issues that could arise by not messing with the carbs? Or are you simply not getting the most out of the mod?
blackcherrycamaro
Did air box mod to 03 Rx-1, Only could test in big field behind house, trails locally closed, but it was enough of a run to test it out, it ran scary strong, no bog issues. I installed
165 mains, 22.5 Pilots, Silver Holtzman Springs and CR10EK Plugs. I'm spot on with Ulmer Clutch Kit, revs to 10200 than will slowly increase to 10,300 to 10,500. One unexpected result, is that it seams to be running cleaner, less visible exhaust, sounds meaner, happy I did the mod so far, can't wait to burn down the trail.
spr5088
Do you run this mod with the tool box/luggage box out of the nose of the sled?
You will get more airflow if its gone.
straycat03rx1
- Aug 6, 2014
- t cats out the a$$ one rx1
will it run leaner with those items gone and a stock air box? I want the wait gone.
Lightly leaner.will it run leaner with those items gone and a stock air box? I want the wait gone.
DJsTuffMods
So i purchased 165 mains and 22.5 pilots(just encase), from Dennis Kirk, and have been running the NGK CR9EIX Iridium plugs which have been working swell. I only purchased the white secondary spring, because my 03 rx1 has the same parts as the stock 05 Warrior as sled dog mentioned about his clutching.. Was the 03 RX1 primary setup the same as the 05 Warrior? According to the parts and info i found they are.. Am i loosing it or is this a fact? Looking very forward to tackling this MOD!
- 32K
