Devo23
Just read in supertrax magazine that the nytro has 110 ft/lbs peak torque. Thats sounds a lot better than 94 ft/lbs which i thought it had. I wonder if this fact is correct or if supertrax mag bent the facts a little. I also read the new 800 RMK dragon will have 103 ft/lbs torque, thats pretty good for a stock 2 stroke. Also saw that mcxpress realeased turbo that puts out 240 hp for a stage one kit for $6500 ca.
PwdrNut
MCX hasn't released anything yet. The kit is still in developement. They are expecting about 230-240 for hp.
DITCHBANGER
i dont think stock tq will be above 100,94-96 sounds about right..maybe with a pipe it will peak at 100..94 is good as it holds it for a good rpm range..
Turk
Tech Advisor
Peak torque is definately over 100 ft pounds. 110 sounds a little high but might be close.
Devo23
the torque sounds higher than what i read before too, just wanted to see if anyone had some bulletproof numbers on the torque. Not sure why mcxpress would post a turbo kit price and horsepower number for something that wasn't built yet, im not sayin that they have the turbo built already , just seems kinda like false advertisement to me if they havent finished one yet.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Devo23 said:the torque sounds higher than what i read before too, just wanted to see if anyone had some bulletproof numbers on the torque. Not sure why mcxpress would post a turbo kit price and horsepower number for something that wasn't built yet, im not sayin that they have the turbo built already , just seems kinda like false advertisement to me if they havent finished one yet.
they will probably tell people they have like 240hp for 10psi... which is crazy.. but anyway.. will make good power... just dyno it once you have installed turbo kit to have the true hp...
obr
it made 230 hp@0.95 bar, wich is 14 psi...
- 11K
- 11K
- 46K
