snowdust
I see Hurricane offers a pump upgrade with a new regulator but it's not adjustable. They say it's good to 500hp and is designed to run at stock pressure. I don't follow the logic. What am I missing?
Hurricane Fuel Supply Kit - Hurricane Performance
This Hurricane fuel pump and pressure regulator kit is needed for tunes over 300HP on the Sidewinder-Thundercat 998. This kit is designed to fit like OEM and will supply fuel for over 500HP while addressing known low fuel starvation issues by returning the fuel directly into the fuel bowl. The...
hurricaneperformance.ca
Doesn't have to be adjustable to supply more fuel.
snowdust
That’s what I don’t follow. At the same pressure how is more fuel delivered?
Volume. Are you datalogging?That’s what I don’t follow. At the same pressure how is more fuel delivered?
I recently had someone tell me that even at 270HP, the stock fuel pump wasn't keeping up.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Strike all that...that kit looks like a high pressure fuel pump & return line to the slipper.That’s what I don’t follow. At the same pressure how is more fuel delivered?
Non adj. Regulator, doesn't make sense to me. "Scratching my head"
Doc Harley
- Oct 17, 2016
- Here & there
I thought the regulator was on the return side of the fuel system. So, how would that allow for more volume?!?!Volume. Are you datalogging?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The Hurricane big regulator is capable of more flow with their big pump, if you tried to use the stock regulator it would over pressurize with their big pump and have too much fuel pressure. Big pump allows for consistent fuel pressure at high HP ratings.
snowdust
Hmmm so why mess with an adjustable regulator? Somehow is self adjusts for ~200 hp difference?
KnappAttack
- Feb 19, 2004
- Welch MN
Adjustable reg allows for enriching or leaning of the A/F of the base tune, non adjustable does not. Has nothing to do with power levels.
NYTurbo
Hurricane also goes to bigger injectors at a certain level where others just up the pressure
Doc Harley
- Oct 17, 2016
- Here & there
Snowdust, real quick,
I've installed a big pump recently, as well as another member on Ty.
I do not have CL or data logging, adj. Fpr, he does. Both of us lost MPG of about 2mpg.
Unfortunately, my short ride of 85miles was heavy on/off throttle. (That's not how I normally ride) my afr was 11.9 to 12.5 which I assume is typical.
He could possibly have a bad O2 sensor?!?! He's looking into it now. He's watching the "poor fuel mileage" thread here.
Just coincidence?!?! Idk. Just letting you know. He is not the type that likes to air dirty laundry.. I can make a copy of all of his Cl, adj. Fpr, etc statements but I think you get the drift. No need to drag others in any further .
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Been running this regulator(hurricane) since day one on my 2022. Big pump also. I ALSO have a TD adjustable. Few times running hard on race gas and testing I needed just a smidge more fuel, so I will put in the adjustable.. I was running a little lean testing on ice 1000.. Funny thing is it ran the EXACT same AFR on every tune that I have from TD.. No lights but low 12's. AFR on race fuel. Adjustable going in just for those times.. Trail riding I do not run the big tunes.. 240-270 is plenty for me.. I like to ride not race on the trails..
Doc Harley
- Oct 17, 2016
- Here & there
Both of us are running MS17. Jon, I believe you run MS17L?!?! When running eco or whatever are you seeing better mpg?Been running this regulator(hurricane) since day one on my 2022. Big pump also. I ALSO have a TD adjustable. Few times running hard on race gas and testing I needed just a smidge more fuel, so I will put in the adjustable.. I was running a little lean testing on ice 1000.. Funny thing is it ran the EXACT same AFR on every tune that I have from TD.. No lights but low 12's. AFR on race fuel. Adjustable going in just for those times.. Trail riding I do not run the big tunes.. 240-270 is plenty for me.. I like to ride not race on the trails..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I got like 5-6 tunes i think.. I can switch between them with the phone/app.. I ran MS 17 lean at bents.. I tried all the tunes in testing on the lake. I need slightly more belt tension on MS 20.. Starts to slip right at the end of a run.. Any tune lower then this its fine no slip all the way up top on a hold. I only run MS 17 or powertrail or the one under that for trail riding.. Plenty for me.. I dont ride with guys that line up or any of that we just like hammering miles and having fun.. We run 50-70 on the grades not crazy aggressive. Just cruising and its so damn nice on the winders.. Nothing better then just cruising at 60 and lifting the skis.. LOLBoth of us are running MS17. Jon, I believe you run MS17L?!?! When running eco or whatever are you seeing better mpg?
I do not keep track of mileage.. I do know for a fact I get better mileage then a stock GT winder though.. We fill up the same pump and I always beat him by half a gallon for d]sure
Doc Harley
- Oct 17, 2016
- Here & there
Right on....I was running MS17, just too lazy to switch it back. And I thought it would produce better mpg. Idk lol. Also running 6psi of boost at 60mph. Maybe the lower tune wouldn't run as much boost @ 60mph....again idk?!?!I got like 5-6 tunes i think.. I can switch between them with the phone/app.. I ran MS 17 lean at bents.. I tried all the tunes in testing on the lake. I need slightly more belt tension on MS 20.. Starts to slip right at the end of a run.. Any tune lower then this its fine no slip all the way up top on a hold. I only run MS 17 or powertrail or the one under that for trail riding.. Plenty for me.. I dont ride with guys that line up or any of that we just like hammering miles and having fun.. We run 50-70 on the grades not crazy aggressive. Just cruising and its so damn nice on the winders.. Nothing better then just cruising at 60 and lifting the skis.. LOL
- 33K
- 46K
