granto211
Buddy's sled, his second Nytro.
This one has blowen 4 belts in prob 1000 miles. 2 this weekend within 200 miles. He thinks it's his deflection plate bouncing up and causing explosion.
Any experience with this?
Always on PAC trail under throttle
DeepFrz
That's a very interesting theory. I blew my belt (only 400 miles on it) yesterday and noticed the deflection plate seemed a bit loose.
granto211
His is mangled from previous belt blows.
DeepFrz
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Might want to consider a SMB replacement? It's full length under the clutches for approx. $80.00
Dodge Ram
X2. It has saved my butt. But I still broke the SB one with a blown belt. Welded it up and all's good.canoehead said:Might want to consider a SMB replacement? It's full length under the clutches for approx. $80.00
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
ditch the stock piece of junk if it is already bent and buy a schmidt bros one! I just put one on mine and it is WAY better than the stock one, also seems to have helped with the wet left foot.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
BELTS
BUY ULMER RACING CLUTCH KIT , STOCK BELT . WILL BE FASTER BETTER BACKSHIFT MORE FUN AND REPLACE A BELT EACH FALL ! MY 290 HP APEX GETS ONE EACH FALL !!!
mattyg1405
I get thousands of miles out of a belt lately, seems like once the clutching was right I never really change them, ( unless I'm playing on the lake)
Nytro0316
I also have schmidt bros. and have no problems!
- 33K
