TurboTime
Allen,
What is your helix degree for the nytro turbo application. Also, what would be the tip weight set up for 15 lbs.
Thanks,
Thanks,
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
For 15 lbs I would run our G helix, 60Y Super Tips setup around 78 or so grams.
TurboTime
Nytro XTX Turbo Clutching
I will be switching between 8lbs (Trail) and 15lbs (Racing). I currently run your K helix with your super tips, (not sure what "60Y" means).
My current tip set up for 8lbs is:
Primary Spring: O-P-O
Heel: Tungsten insert & 1 washer
Mid: Empty
Tip: 2 washers
What are my options?
Thanks in advance,
Srxspec said:For 15 lbs I would run our G helix, 60Y Super Tips setup around 78 or so grams.
Mid: Empty
Tip: 2 washers
Thanks in advance,
- Apr 17, 2003
- Menno, SD
- Menno, SD
60Y is the 60 gram Super Tips.
Load up the heel for 15 lbs. Tungsten in both spots at the heel, 3 in the middle, 3 in the tip. White secondary spring set at 6-1 with the K helix.
TurboTime
Srxspec said:60Y is the 60 gram Super Tips.
Thank you Allen, much appreciated. Ill start to dial her in once we get snow...
Frozenstiff
- Dec 24, 2009
- Prescott, Ontario
- 2013 Arctic Cat Turbo
Allen, What is the part # of the white secondary spring ?
- Apr 17, 2003
- Menno, SD
- Menno, SD
90508-60007-00
