bjerrang
Hi ive extended my bars and i have rerouted the throttle cable. I still get tors warning on full steering deflection. Where to buy and extended cable or another cable from yammi ?
i do not know where to get an extension from but i do know that all the phazer models use the same cable. been looking as i waqnt add a riser to my rtx.
bjerrang
IF you reroute the cable i think its ok. The mtx has a bigger riser and is stretched alreadyi do not know where to get an extension from but i do know that all the phazer models use the same cable. been looking as i waqnt add a riser to my rtx.
mtx riser is the same part # as the rtx riser and the standard phazer riser. just checked the parts fiche from 2007-2017 and the part # is the same on all of them.
bjerrang
YEah , anyway my cable is to short . Got a higher rsi bars and it tors every time i turn fully. And i also looking for the summit strap for the rsi handlebar. RSI does not reply on email at all.mtx riser is the same part # as the rtx riser and the standard phazer riser. just checked the parts fiche from 2007-2017 and the part # is the same on all of them.
bjerrang
this one https://www.snowest.com/forum/attachment.php?attachmentid=74425&d=1251763989 , anyone know where to find this aswell ?
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
I have those same RSI bars (have not installed yet) and found that the mountain/grab strap is basically the same as what Polaris uses on their RMK Pro models (and probably some others). I would try checking Polaris parts diagrams and I'm sure you can find a part number for the strap that way.this one https://www.snowest.com/forum/attachment.php?attachmentid=74425&d=1251763989 , anyone know where to find this aswell ?
Regarding the extended throttle cable, I would think that an extended cable from another Yamaha 4-stroke sled would also work, though I have no idea what their length is compared to the Phazer. Probably an easier option would be to try a throttle cable extension kit such as this one:
https://powermaddstore.com/pm/product.php?productid=188&cat=182&page=2
Snowmixer
- Oct 29, 2010
2008 Phazer MTX
Oops...double posted!
