stgdz
- Mar 27, 2021
- Buffalo MN
Saw this mentioned sometime last year and I had it bookmark'd but now I can't find it. Basically they pinned the driveshaft and then cut a small slot in the bearing. I believe they also welded and lathed the shaft of any worn down spots.
It was a dealer out on the east coast that offered the service.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Franks Motorcycle
120 Centre Road
Essex Junction
VT, USA
05451
802 878 3930
Ask for Kamran Peckey
You send them your shaft, they spray weld it, and bring the tolerances back up.
They will pin the shaft and key the bearing.
PM if you have more questions.
MS
DTJ
- Mar 31, 2016
- Brainerd, MN
- 2014 Yamaha Viper XTX, hurricane 190 kit
2013 Yamaha Apex XTX
2017 Yamaha Sidewinder BTX
I had DMS machine in Little Falls do it for me if your looking for someplace not so far. Talk to Rick.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
How has the machined bearing been lasting?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
I just heard of this process last season, so it will likely to take a few seasons to hear some details. I see no reason why it wont produce identical km's to the stock set up.
MS
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
generally speaking, bearing manufacturers use the least amount of steel in that area that they can get away with, (minimum thickness coincides with minimum cost) and there is no strength top spare. That is one of the reasons they polish the area to a mirror finish. Also the heat treated components of the bearing are very sensitive to fatigue. This was told to me by an engineer, so i am curious to how well it lasts.I just heard of this process last season, so it will likely to take a few seasons to hear some details. I see no reason why it wont produce identical km's to the stock set up.
MS
sidewinder 2018
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour
I rode a full season last year( 1,500 miles)with this repair,with no issues.less than the cost of a new drive shaft.post #2 of this thread has contact info.see thread #11 on this subject for the updated repair from BOPgenerally speaking, bearing manufacturers use the least amount of steel in that area that they can get away with, (minimum thickness coincides with minimum cost) and there is no strength top spare. That is one of the reasons they polish the area to a mirror finish. Also the heat treated components of the bearing are very sensitive to fatigue. This was told to me by an engineer, so i am curious to how well it lasts.
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
Thanks for the feedback. I'm going to machine a few around here for spares. I'm thinking that as long as I can keep the keyway tight on the pin, I should be ok. Probably throw some green stuff on there as well. I could see if the keyway was a bit loose, it would shear off the pin from accelerating and deceleration
sidewinder 2018
- Feb 13, 2017
- Amston,CT
the width of the slot was with in .001 to ..002 larger in width than the pin for easier assy. No longer needed the BOP shaft saver, he can sell you the slotted bearing that he uses with that repair.Around $40 and is upgraded from stock
sidewinder 2018
- Feb 13, 2017
- Amston,CT
After 2 full seasons, and 3k miles,I checked my anti rotation pin.It was worn to the point that it was almost peened over and I decided, while apart ,to update this repair with the BOP new concept lower driveshaft bear.Best $160. You will spend while using your same lower driveshaft.I now have close to 10 k on my original lower shaft.This updated repair I have monitored this past season, with no issues.Just be sure to add locktite on the 3 set screws at final assy
sidewinder 2018
- Feb 13, 2017
- Amston,CT
After 2 full seasons, and 3k miles,I checked my anti rotation pin.It was worn to the point that it was almost peeled over and I decided, while apart ,to update this repair with the BOP new concept lower driveshaft bearing repair..Best $160. you will spend ,while using your same lower driveshaft. The remaining part of the pin was ground flush to the surface of the shaft and the debris shield was cut off the shaft.I have close to 10 k on my original lower shaft currently.This updated repair I have monitored this past season with no issues.Just be sure to add locktite on the 3 set screws at final assy when installing.
ents
- 51K
- 12K
