stingray719
Ok so awhile back I put on a g w g and wanted to shim it also but never could find a shim for my sled no matter who I called most of the dealers up this way didn't even know what I wanted one dealers said they found them and they would order for me, perfect. Got them in and they were the belt adjustment shim wtf. So if someone could tell me where I can get shims I would appreciate it.
Yamaha shims may not be thick enough, do a quick google search for "Yamaha primary clutch shim" and pick the vendor whose name starts with "B"...lol
stingray719
Yamaha part # 90201-483P9-00
Yep! I use one of the part number Shagman lists and one 6mm shim for a 7mm total. I recommend starting at 2 and test I suspect 4mm to 6mm will work the best for your application.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Just gathering info for when my parts arrive!!
What is torque for the clutch cover bolts ?(with blue loctight)
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
10 lbs. ft. I would not use loctite on those bolts. JMO
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
thanks!!! how about the clutch weights?10 lbs. ft. I would not use loctite on those bolts. JMO
secondary bolts for the helix?
and bolts for shimming for 8dn?
shagman
Vendor
- Feb 18, 2014
I'll post when I get home and lookup for you.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
shagman
Vendor
- Feb 18, 2014
weight bolts 4.3 ft. lbs.thanks!!! how about the clutch weights?
helix bolts 17 ft. lbs.
main secondary bolt 44 ft. lbs.
Just an FYI if you join as a VIP you will have access to the service manual and other neat things. under the VIP tab up top.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
thanks again Mr.SHAGMANweight bolts 4.3 ft. lbs.
