dburrowes
- Jan 7, 2009
- Brooklin, Ontario, Canada
- 2015 Yamaha Viper LTX-SE
has anyone tried using an insulated flexible duct from the front of the sled inside and through to the air intake of the turbo. I noticed the air intake temperature was very high today while running rail lines at -8c. Obviously quite warm under the hood.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I have the "out of the hood" intake, I saw 2 - 5*f intake temps at slower (25-40mph, novice rider with me) speeds with ambient air temps at 0 - 4*f. Easiest would be to get it out from under the hood and over the clutches.
Poechman
- Sep 23, 2015
- Hanover, ON
- 05 RX-1Ton
16 viper ltx
I believe there's a kit you can buy that will direct your intake to the nose of the machine, keeping your "sleeper" look. I ran my intake under hood for about 1500 km before routing it outside of the machine. Noticed a huge difference in intake temps and power!!
DelgatyXTX
I've got the MPI kit so I know it's a bit of a different setup than yours but because my aluminum tube crosses right over my engine I wrapped it in fiberglass header wrap. My intake temps are right in the midrange regardless of outdoor temp.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I would like info o this set up if you have it.I believe there's a kit you can buy that will direct your intake to the nose of the machine, keeping your "sleeper" look. I ran my intake under hood for about 1500 km before routing it outside of the machine. Noticed a huge difference in intake temps and power!!
Poechman
- Sep 23, 2015
- Hanover, ON
- 05 RX-1Ton
16 viper ltx
I personally do not have the intake directed to the nose, I did see it posted somewhere on here tho and believe they were selling a kit, possibly ulmer? I ran intake under hood from the dealer it sat just above the clutches on the guard. After comparing intake temps and performance with one of my buddies with the same setup but intake out the hood, we found he was running way lower temps and seemed to make more power... I put my intake out the hood and noticed some big improvements!I would like info o this set up if you have it.
Poechman
- Sep 23, 2015
- Hanover, ON
- 05 RX-1Ton
16 viper ltx
There is some more info on this thread.. http://ty4stroke.com/threads/turbo-intake-ideas.139192/
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I had my intake for my Hurricane 190 on the nose first of this season and now moved it to just beside the rad in the hood area. I drop intake temps about 20deg . Outside air -12C intake temps were about 15C where in the nose they were 35C and higher if I went slow
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Got a picture of your set up? My intake piece is out right now. I am going to try to make something tomorrow and need some ideas.
hellflyer
- Dec 2, 2008
I thought I took a picture but can't find it on my phone! I can take one in the morning ,sled is at my shop. I basically have it sitting right beside the back right side of the rad.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Cool, I'll look for it
Dicker from JP
- Nov 12, 2014
- Jacksons Point,Ont
- 2015 srViper l-tx se
pictures would be great. I'm also looking for some samples of what's working for guys.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
I do believe this is mr sleds. I'm running the exact same thing. Seems to work well.
hellflyer
- Dec 2, 2008
I had mine there first but runs much cooler up beside the rad on my sled!
tapex_07
- Feb 15, 2009
The only thing I might question with it under the rad is that you're still getting unwanted heat from the rad as it cools. The amount of heat is huge! I have my fan on a switch reversed and when I stop and turn it on, it'll warm your hands up through your gloves in less than a minute. Coolant temps in the 170-190*. That's the only reason I put mine out of the hood and away from any undesired heat.
