Reinforcing 3cyl exhaust pipes
TrueBlue
Franklin Park, IL
Area that breaks is right past the 3 Y-pipes about 2'' on the single pipe where it has been welded from the factory. In the diagram you will see a small line around the pipe. Is there any way to reinforce that area. These pipes are steel & that's where they seem to break.
Forgot to install diagram. Here it is.
