TC Rides
- Feb 1, 2019
- Wilmette, IL
- 2007 Yamaha Apex GT
So, I pulled the trigger and installed a Seat Concepts/ WRP foam and cover kit on my '07 Apex. The entire project is pretty simple, if a bit of busy work pulling old stables (maybe 130?). New foam went on (with a Styrofoam insert) and cover centered and stapled onto old seat pan... taut but not stretched.
I am keeping the original cover as it is in good shape. and I could use it if the new cover gets torn; Is there any reason I should consider keeping the old foam? It is original, and while it is in one piece, it certainly is not in new shape. I just can't think of a reason to keep it.
All thoughts welcome!
-TC
-TC
i kept the foam from the seat i put the kit on. probably going to toss it as it was sacked out with 18000 mi of riding on it.
TC Rides
- Feb 1, 2019
- Wilmette, IL
That’s the thing… I bet I’ll store this for a couple years then after I get fed up tripping over it 150 times I’ll just say ‘screw it’ and toss it anyway. I figured if there was something to do with it, someone here would have thought of it already.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
Looks awesome. I was thinking of picking one up for my 07 Nytro!!!
i got one for the phazer rtx/x and it made a difference on that sled.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
might want to keep your foam, I went back to my stock seat after 2 rides, Concepts wasn't for my riding style.So, I pulled the trigger and installed a Seat Concepts/ WRP foam and cover kit on my '07 Apex. The entire project is pretty simple, if a bit of busy work pulling old stables (maybe 130?). New foam went on (with a Styrofoam insert) and cover centered and stapled onto old seat pan... taut but not stretched.
-TC
Seavey82
Same I knew right away it wasn't for me and went back to stock. I was not impressed with the quality of seat concepts either.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Put one on my 2007 Attak last year, wish I did it sooner. Seating position is better (I have a 2” riser), looks better and it’s much more comfortable. The combination of that and the Simmons Flexi skis turned it into a much better sled.
