Here are a few pics of the SideWinder MTX Chain Case.
princesledalot
- Feb 8, 2006
- East Pouce
- 04 RX1 13 apex se 96 vmax 4 aerocharged
- Pouce Coupe BC
This looks way better than other chain cases with reverse. Are these parts Yamaha or Arctic Cat ?
It's basically a Cat design but changes such as Manual Chain Tensioner and Yamaha style chain were added when Viper came out. Since then every year there has been changes. Now with Sidewinder it has a 15 wide chain.This looks way better than other chain cases with reverse. Are these parts Yamaha or Arctic Cat ?
My question is did Yamaha drop the chaincase and move footwell forward on the Mountain sleds like Cat did?
Mtnviper
Vendor
No drop and roll for the Viper/Sidewinder this year. Only select M8000 sleds got the new chain case and footwell mods.
Maybe next year!
Edit: Looks like the just released M9000 King Cat 162" is getting a dropped chain case.
Need help with this!!# where do you set bronze gear in chain case
The one for reverse servo?Need help with this!!# where do you set bronze gear in chain case
Yes for the reverse servo the gear that slides inside on the 2 pins where do I set that before I put servo gold gear into place thanks!!
If its not in FAQ here the answer is in Viper FAQ most times.
http://ty4stroke.com/threads/technical-bulletin-s2014-001-reverse-update.126073/
Set gear all the way in. That's forward.
kayl Williams
- Oct 2, 2017
- Pingree Idaho
- Yamaha sidewinder
Can you put the 2018 drop roll chaincase in the 2017 yamaha sidewinder?
Carla 123
- Feb 27, 2017
- Lester beach
- 2015 viper xtx boosted
17 zr9000 precision stage 3
And still no drain plug to make changing the oil easier?
easton
- Nov 10, 2017
- Easton,WA
- 2017 sidewinder mtx sleeper
2007 apex
took my chain case apart and the whole reverse bs fell apart looking at it I have it assembled correct but there is a spring and a bushing that I cant figure out where they go do you have pics of that?
Take a pic of what you are talking about.took my chain case apart and the whole reverse bs fell apart looking at it I have it assembled correct but there is a spring and a bushing that I cant figure out where they go do you have pics of that?
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
