Big Bertha
Hey there, I’m rebuilding my skid on a 2018 VK Pro 2. It needs all bearings and bushings etc. is there a good quality aftermarket kit for that? A kit that includes all the rebuild parts I would need??
Or is it buying each piece separately from the dealer? Thanx
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
I don’t know of any kits,usually I purchase good quality bearings from a bearing supplier,generally online you can get a discount for buying in quantity,most of the rear suspension bushings I purchase from yamaha as they are usually not readily available aftermarket, some people use just cheap idler wheel bearings but I generally buy higher quality depends on preferenceHey there, I’m rebuilding my skid on a 2018 VK Pro 2. It needs all bearings and bushings etc. is there a good quality aftermarket kit for that? A kit that includes all the rebuild parts I would need??
Big Bertha
Ok got it. Now what’s a good bearing manufacturer that’s reasonably priced?
Jack_Shaft
NTN is hard to beat. Just make sure they have rubber seals and not plastic. Royal Distributing sells 6004 and 6205 brgs by the 10-pk for a reasonable price, that's where I buy mine.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Figure out which size bearings your wheels take, Royal Distributing covers off most bearings for sleds and their prices are reasonable. Settle for NTN bearings and they will treat you well.
As for bushings.... that can get expensive when you buy all the little bushings for a skid.
I often take my bushings and use the wire wheel on the bench grinder and clean them all up. Just stick them on a screw driver and rotate while the wheel cleans them up.
I have a wire brushing kit (from Princess Auto) that I spin on the drill and clean the eye holes. It take the rust out of shock eyes etc.
Hope that helps.
MS
Hope that helps.
MS
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
Timken makes a great bearing. I used to run the cheap bearings but gave up after a few failures. It really depends how many miles you put on in a year. Last year a ran 4000 kms. I had a bearing in the upper idler wheels lock up and spin in the plastic wheel. It was a cheapy bearing. The NTN bearings on the factory accessory back wheel I got nearly 10,000 kms out of them!!!
Big Bertha
Ok, thanx for all the info. I’ll check out Royal D and see what they have. Now, for the next issue is the sagging rear suspension!! It’s like the torsion springs are not strong enough to keep the rear end up. It says all the way down to the stops and sits there while I ride. Very bumpy and bad steering as a result! Any ideas about that?
Big Bertha
Big Bertha
Here is a little vid of the issue? Is there some aftermarket thing that will stop the drop? I’m always riding on the bottom bump stops. Rides like total #*$&@ as a result.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Your shocks are tired and need to be rebuilt. No big deal.Ok, thanx for all the info. I’ll check out Royal D and see what they have. Now, for the next issue is the sagging rear suspension!! It’s like the torsion springs are not strong enough to keep the rear end up. It says all the way down to the stops and sits there while I ride. Very bumpy and bad steering as a result! Any ideas about that?
MS
Big Bertha
Ok, so you think it’s the shock. I’m looking for a replacement already just to be ready. What about the springs? Do these torsion springs get weak as well? They look ok but can they loose their power?Your shocks are tired and need to be rebuilt. No big deal.
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
The only way i can see springs failing or weakening is if you stored the sled with a ton or weight on it - or something like that.
If it was stored with the rear end raised - those springs are fine. The springs on these sleds are pretty strong.
If the bushings in your sled's skid are dry and rusty, if the rear scissor isnt greased and the shocks are old - it will not fully rebound. Sounds like it is need of some TLC.
MS
MS
x2 on the shock.
i do have a weak set of springs with 35000 km on them and they are bottoming on a fresh shock on the hardest setting on 5 position blocks i have on the sled. took 4 seasons of fresh shock every year before i had to condem the springs for being too weak.
Big Bertha
Ok, what happened when the new springs went in? Did the tide hight return back to the top?x2 on the shock.
have not installed them in it yet. when i get to its pre season i will but that will not be for at least a month with all the other repairs i need to do.Ok, what happened when the new springs went in? Did the tide hight return back to the top?
