Gone Blue
- Oct 11, 2006
- Howell, Michigan
Well after 4 plus thousand miles on my 2008' RTX stretched to 144' since I bought and built it, I think its time to try and reduce the darting that I always tell myself is not that bad, lol. I have a totally stock 08' front end and have been running 6.9 Pilots with 6" carbides down the center and 4' on the outside. I have been happy with the handling and steering effort with these skis and my suspension set up for how I ride. Just looking to tame the darting and everyone also mentions how great Snow Trackers are. I just installed the Semi-Aggressive carbide set up for Pilot skis. Still need to adjust my ski alignment to a zero toe. So we will see how these work and if they are worth the money! G.B.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
are your front end bushings tight?
mine where loose @1100 miles
Gone Blue
- Oct 11, 2006
- Howell, Michigan
The front end is still pretty tight. I installed oillite bushings in the A arms, all new Yamaha ball joints, and UPBushmans SS spindle kit 4,000 miles ago, and new outer Yamaha tie rod ends last year. Darting is snow and trail condition variable, I am interested in seeing if Snow Trackers work as well as most people say they do.are your front end bushings tight?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
They will.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Welcome to a whole new level of steering control. After checking it out you might choose to lighten the preload on the ski springs if needed. All I can say is you're going to kick your self for waiting so long to try them.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
They eliminate darting when the correctors are good, when the correctors wear down, they will steer harder and dart on firmer conditions.
IMO you should have done the Aggressive. The semis will certainly push more.
