SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Guys running closed loop, do I need to always let the sensor warm up? Should be SD 24......
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
It does not have to warm up to function, but I like to turn the key on, connect my phone to the flasher and then start the sled. Sometimes if just starting the phone won't connect every time.
If you have no flasher or phone it makes no difference. Don't even give the code a second thought, it goes out when the sensor warms up.
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
always let sensor warm up ... do not keep turning ign on and off without it completing cycle or will destroy sensor.
SideHogger
- Apr 16, 2016
- upstate ny
Just kinda worried it puts strain on battery cause it will show low volts but once started it goes up to normal volts of 14.2.
justinator
Your voltage will be quite a bit lower without sled running anyway and what is displayed on the dash on my sled with key on/sled off is lower than what I actually have at the battery. I believe its a non issue.
You dont have to let the sensor warm up, like knapp said ignore it and go. Vehicles have the same process going on but the code does not appear while it warms because a preset amount of time is programmed into the ecu to allow the sensor to warm. You will only see a code on a vehicle if the sensor is faulty. This delay is not programmed in the sled ecu so the code flashes while the sensor warms.
SideHogger
- Apr 16, 2016
- upstate ny
Thanks as usual guys. I’ve been letting it sit with key on and waiting for SD 24 to stop flashing thinking the same as max rolph that you have to wait til it goes off. Didn’t like leaving key on any longer than you have to.
- 6K
