yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Just finished building and painting up 4 aluminum filler plates to fill the hole after removing the sway bar. I have the plates ready for the XTX LE once it arrives, soon I hope! Busy work till the snow gets here....
stingray719
I left the sway bar on and just removed the links. Maybe not the best way but one day I will trade it in or sell it and I can put back on. Nice looking plates you made though.
yamahaguy
Ride SAFE
- Apr 20, 2014
I can still remove the plates and install the sway bar back on. The plates are just held in place with the original sway bar bolts. not that I will notice but small weight savings up front to
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Looks great good job.
I am and trail guy and need the sway bar so won't be using.
09nytro
Those look nice !!!!
Now much are they a set
weasel33
If your an active rider no sway bar means you can lean the sled into the corner and rail around it. If your not active don't remove it. But some of us trail guys still remove them.
09nytro
I take mine out all the time , I like it much better with out sway bar
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
What do you guys mean by "active"?
weasel33
Being active means you move around a lot on your sled. The faster you go the more you have to lean off the sled when going around a corner. If you just sit back and stay planted on the seat the sled wil roll to the outside of the corner if you don't have a sway bar.
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
Thanks weasel33. That is what I thought you were referring to. Appreciate the clarification.
Shane
Shane
weasel33
Shane
yamahaguy
Ride SAFE
- Apr 20, 2014
I ride 90% off trail riding so things like carving and side hilling are a lot easier with the sway bar off, the sled becomes more flickable and does what you want with less rider input in deeper snow. As weasel33 said, you need to lean into corners if your trail riding. This mod is best for off trail riding mostly. Thanks for the complement guys and to 09nytro i'm not really selling them it was just a scrap aluminum i had laying around, just some cutting, griding, sanding, drilling and a beer or 2 and you have a set in 15-30mins
- 7K
- 14K
- 8K
