OUCH!IMO, they MIGHT be ok on box stock sleds (including stock gearing and no studs). But there aren't very many like that. On big tunes with lots of studs, I think they're ticking time bombs.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I started this post in hopes of running the TEAM primary on the winders and preventing the premature roller wear, quiet the clutch rattle and prevent belt blowing we've experience from the Winder primary on the big tunes, but it was apparent to me that they slip really bad down low while performing just normal trail riding. I'm sure with what I know now and using a XS belt on it, there could have been much less slippage, but none the less, the cracks appear from what we call heat checking, which is slippage. And the more abuse put to the TEAM, the quicker they are going to crack. The TEAM has another flaw, the use the wimpy cover to limit the sheave travel rather than let the two sheaves do the limiting. The stock cover can't take that abuse and breaks taking the movable with it in the process when it blows.
I've now fixed my premature roller failure by going to the old RX-1 primary clutch, an Apex clutch has also fixed my buddies rollers issues. He was eating rollers on a daily and weekly basis. Although the old clutches still rattle, its not heard because we both wear ear plugs and don't use stock exhaust anyway, and the rattle is just the spider to tower clearance. One thing we both noticed was increased performance when going to the old style Yamaha clutches. My Winder clutch seemed to bind up and limit performance and make it hard on belt life, not sure if the shaft has grown on it and sticking on the movable bushing, or if it's the tower to button clearance, but I know it binds, and just set it on the shelf. The RX-1 clutch works very well, does not bind and does not eat rollers & belts for breakfast, in fact my buddy is still using the 8JP with success, I'm using the XS825. One thing I know for certain is the old primary lays down more track HP than the winder primary, at least it does in my case and I had to learn it the hard way earlier this season.
johan
Is the 911 cover dialed down to match the yamaha belt width?
If so how did it affect your engagement RPM?
Yes I use the cover to dial in the belt. I have a Polaris yellow spring and my engagement is 2850rpm.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
OMG when did this happen? I hope your going to be ok?
johan
You dont think it was the secondary that blowed here first? i have seen a lot of the boss teams blowing but not the primary.IMO, they MIGHT be ok on box stock sleds (including stock gearing and no studs). But there aren't very many like that. On big tunes with lots of studs, I think they're ticking time bombs.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I am guessing the secondary!!! I know the guy who blew clutches apart!!! He had he secondary apart a few times doing adjustments with the torsional conversion and chasing top end speeds!!You dont think it was the secondary that blowed here first? i have seen a lot of the boss teams blowing but not the primary.
He had a few blown belts prior to catastrophic failure.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I been paying close attention to my teams clutches since new!! My cat has been tunes since 0km and the team clutches are holding up great!
0 blown belts
0 slippage
No excessive heat
Clutch faces are like new after 1000km!!!
0 blown belts
0 slippage
No excessive heat
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
0 blown belts
0 slippage
No excessive heat
1000kms and the engine isn't even broken in yet, lol. See if it last to 10,000+kms.
Turboflash
- Mar 18, 2019
- Southern MN
My thoughts too. I have 5200 miles = 8,368 kms. First 4500 @ 280 tune, 192 ea. 1.630" studs, 21/38 gearing. Last 700 miles @ 320 tune w 22/37 gear.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
1000km this year so far running the 270 and 300 header ss tune1000kms and the engine isn't even broken in yet, lol. See if it last to 10,000+kms.
Last year I run the sm tune for most of season and pm bundle at the end of season
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
On your team clutches?My thoughts too. I have 5200 miles = 8,368 kms. First 4500 @ 280 tune, 192 ea. 1.630" studs, 21/38 gearing. Last 700 miles @ 320 tune w 22/37 gear.
Turboflash
- Mar 18, 2019
- Southern MN
Total miles, yes. Sled is 3 yrs old. My point is only that my Team clutches both looked like new until about 3 weeks ago when I noticed cracks in my movable. I had to replace primary. The spider, bushings, rollers, weights, etc still like new. Just cracks in movable starting way down at center hub radiating outward. At 320, I don't wonder why stuff can't hold up. It's the price to play.On your team clutches?
These are a number of Team clutches on tuned TCats. Lowest has 1500 miles, mine (pic 1) has 4200 miles. I check my nephews 2017 TCat (280 tune) with 4200 miles on it this weekend and his is cracked too. Seems like with a big tune and lots of long studs, maybe about 3500-4000 miles might be the limit.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Did you replace with oem or billet clutch?Total miles, yes. Sled is 3 yrs old. My point is only that my Team clutches both looked like new until about 3 weeks ago when I noticed cracks in my movable. I had to replace primary. The spider, bushings, rollers, weights, etc still like new. Just cracks in movable starting way down at center hub radiating outward. At 320, I don't wonder why stuff can't hold up. It's the price to play.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
The cracks are caused by belt slippage down low. Sounds like Knapp was right about the team primarys not having enough grab down low.
Nice magnifying glass by the way TF!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
On the older F1100t cats they had this same issue, you had to shim the spider on tuned sleds to prevent the slipping.
- 13K
