ken_climb
pro116
If your going to use boost I would recommend some rail reinforcenments.It 's basically the same skid as the apex mtn.
DITCHBANGER
id would sacrifice a bit more weight and a better performing skid with the zx2,take most the wheels off the zx2 and your prob around 43-45 lbs for a 151..
Bodacious
I can't even vision Ken Climb without at lease one Turbo spoolin'!pro116 said:If your going to use boost I would recommend some rail reinforcenments.It 's basically the same skid as the apex mtn.
4strokes are better than2
i hope so ken i ordered one for my vector they are 38lbs with apex 162 rails that is a ac skid version & this skid in no way is like a apex skid if you look at the shock & a-arm angles its more like a m-10 than a apex skid but you can make this skid transfer or not by adding transfer blocks.the owner has run one for a couple years now on his apex that is supercharged without any issues
pro116
I ment the nytro mtn skid and the apex skid are the same in factory terms.Lot's of guys are having problems bending and cracking rails on the apex so without adding any braces the skid will be weak more so witrh boost,Sorry if I worded it wrong in the first post.
ok i get what you are talking about now.it funny all the apexs around here i have not seen a broken rail yet i wonder if it was just a bad batch of metal.
