2datrl
My 2012 Vector now has over 8000 miles on it. Noticed after the last trip that most track clips are compromised or missing. So I can buy clips for about $130.00 and hopefully borrow the tool to rebuild the track that might have 2000-4000 miles of life left, or replace the track for more like $400.00 which would also give me the opportunity to replace the drive shaft bearings and such. BTW, 1 stud did pull out/ missing with no apparent track damage.
Any thoughts and / or high mileage Vectors out there?
2datrl
2datrl
theCATman
New track hands down.
Check with Travis at Barn of Parts. Good chance he has a new take off, or super low miles one off a wrecked sled.
That's what I did for my Apex. (6600 miles on original) I got a like new, studded Cobra from a wrecked sled from him for $150 or $175 shipped. Been 3 years ago, can't recall price, but it was one or the other.
Sent from my SM-G930R4 using Tapatalk
Metallicat
New track X2! My clips are wearing thin after 11000 miles. None missing yet that I know of. I completely reclipped a track once and would rather just put a new one on this time around. I've heard the Ripsaw II tracks are much better than the original. But maybe you already have an R2.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 14600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 19500 km
2010 Vector LTX GT 25000 km sold
New Track for sure, I put 19000km on my Vector track and I changed it out because the track was peeling rubber out on the inside where I had installed Tricked toys aluminum 135mm idle wheels and rear axle wheels. Put in a ripsaw 2 with studs and found the rear end to be a little unpredictable in the corners as compared to the original ripsaw that was studded also. Also when back to regular oversized idler wheels as the aluminum was great looking but they built up ice and on those long days the vibration was bothersome not to mention the track damage being done.
Metallicat
The Ripsaw 2 is supposed to have less side bite in the corners so maybe that is what you are experiencing?
TrueBlue
2datrl
You must ride your machine hard. My 2011 Vector has 11,000 on it & all the clips are there & the track is in great shape.
2datrl
I do ride hard, but I think that the DuPont Vespel slides might have something to do with it, as well as junk conditions this past season.
2datrl.
2datrl.
TrueBlue
2datrl.
If you think that the DuPont slides wear the track clips down because they are harder than I rather just buy the OEM ones and save all the work of replacing the track clips.
2datrl
I will be going with normal Hyfax this time around. I will also try to avoid sand based snirt trails as well.
2datrl
2datrl
