yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
I have read on here a few of you have pulled them out. I have been thinking about doing this and was woundering how you like it? Did you notice much of a difference or see any problems of removing them? How much did it change the handling of then sled?
Studroes144
Mine still handles the same as far as suspension and steering. Little more weight transfer but now much. Certainly worth doing in my opinion
Yamacat21
What did you actually gain? More ski lift, or more pressure? I like the way mine sticks to the trail, but if you are riding more off trail removing them may be productive.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
Pulled mine out, seems to weight transfer more and definately hooks up better. Didn't really change the way the sled handles either. Worth doing IMO
JTSKIR222
i did mine ltx se
helped a little with transfer but no the fts bottoms out over minor hits.
I never bottomed out the fts before this.
I ride fairly hard..
I can't believe no one else bottoms the fts without blocks.
mine are going back in and trying to figure out the transfer cure with blocks installed.
09nytro
Why do you guys want so much transfer ?
Yamacat21
maybe people are trying to make up for ability in tuning. LOL seems to me no one I ride with can touch me on my viper and the only thing I've changed is carbides.
09nytro
I hear ya !
I changed my windshield too !
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
Yamacat21 said:maybe people are trying to make up for ability in tuning. LOL seems to me no one I ride with can touch me on my viper and the only thing I've changed is carbides.
I agree. I ride very hard as well and I have no problem keeping up with the best of them. I think the Viper handles awesome! And I'm still running stock skis with duals.
I removed the plastic blocks on mine ran 85 rader run remove the whole shaft ran 88 .left it out on the r7de home and its staying out until i can get to revalving the shocks also removed adjusting blocks on rear springs. This sleds is fun and easy to ride like most are saying just to stiff in rear
09nytro
You took the cam to adjust the rear spring out too ?race79 said:I removed the plastic blocks on mine ran 85 rader run remove the whole shaft ran 88 .left it out on the r7de home and its staying out until i can get to revalving the shocks also removed adjusting blocks on rear springs. This sleds is fun and easy to ride like most are saying just to stiff in rear
What ? Why ?
A little less preload I imagine.
yamakazie
For those of you removing the transfer blocks but leaving the aluminum shaft indexed to the flat spot. Are you seeing any damage due to metal on metal contact?
savageman69
- Apr 21, 2014
- 2014 arctic cat zr 7000 limited
took my blocks out but havent rode it yet....my buddies cat has been 2 years no blocks without issues
