Thanks guys. Love those rivets. I think they're the same as the Yamaha rivet as mentioned.
Does someone want to contact Cat and let them know also.
Turboflash
- Mar 18, 2019
- Southern MN
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Last time I ordered 300 of them....
Good for a while now.
stgdz
- Mar 27, 2021
- Buffalo MN
What is the difference between these rivets and the hauck rivet. Can you still get the stavex out if they loosen up?
I think I will have to take a metal grinder to my hauck rivets on my steering bracket should it ever loosen.
YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I used 5/8" long 10-32 black oxide coated stainless steel button head screws, nylon lock nuts, & washers (McMaster-Carr #97763A340 & 94407A113 & 96765A125). These won't loosen up or rust!What button head screws are ppl using?
I placed an order today of all four of those Advel rivets they offer along with a dozen 3/16 drill bits.You can buy them in canada from Applifast. $40.00 for a box of 200. I think you have to make an account. Shipping was fast.
BS01-0618 Stavex Fastener
The Avdel® Stavex® Steel Rivet is a multi-grip, high-strength breakstem fastener that is produced in both steel and stainless steel to meet assembly requirements. This blind rivet can replace several grip fasteners, thereby reducing fastener inventory and simplifying stock control. Avdel Part...shop.applifast.com
Air riveter highly recommended.
Over $250 worth to get free shipping. Prices range from .28 to .34
I think these are the exact same rivet that Yamaha use from the factory on the all Jap models.
earthling
Good call to stock up. Even with shipping (which was fast) the cost is still far lower than buying them from Yamaha and yes, everywhere I have looked says they are the same exact rivet.
They also have those 1/4 structural rivets that Yamaha used in the 1998 and up models where the bracket for the trailing arm attaches to tunnel.Good call to stock up. Even with shipping (which was fast) the cost is still far lower than buying them from Yamaha and yes, everywhere I have looked says they are the same exact rivet.
However, their website didn't allow for me to add them to the cart without calling in.
Turboflash
- Mar 18, 2019
- Southern MN
Key is "structural" rivets. And yes, Avdel has them.They also have those 1/4 structural rivets that Yamaha used in the 1998 and up models where the bracket for the trailing arm attaches to tunnel.
earthling
I have had to call them a few times. They are very helpful.They also have those 1/4 structural rivets that Yamaha used in the 1998 and up models where the bracket for the trailing arm attaches to tunnel.
