Your sleds looks to be a 144 or 136 length track and a 151 will not work. To be sure on exact length of replacement should have been calculated correctly. What year and model is s that? Rx1?
Robi
- Nov 19, 2021
- Saskatchewan
- 2003 Yamaha RX1 mountain
Yes on the bill of sale it’s says 2003 Yamaha RX1 mountainYour sleds looks to be a 144 or 136 length track and a 151 will not work. To be sure on exact length of replacement should have been calculated correctly. What year and model is s that? Rx1?
That sled according to the specs should have been a 151”Yes on the bill of sale it’s says 2003 Yamaha RX1 mountain
Robi
- Nov 19, 2021
- Saskatchewan
Well that’s the size of track that was put on according to the receipt. Is there anyway to identify the size of track? Part number? And where would I find it if so? Gonna take the VIN number to a dealer and find out the exact model. Lol this is confusing.That sled according to the specs should have been a 151”
this is the best way to be sure the track is correct: https://totallyamaha.com/snowmobiles/aaTECH/tracklength/tracklength.htm
RobX-1
- Coldwater, OH
The model number of the track should also be stamped on the track:
Robi
- Nov 19, 2021
- Saskatchewan
It is a 2003 RX1 the guy who sold it to me said it was a RX1 mountain. I did measure the track and it is a 151.Your sleds looks to be a 144 or 136 length track and a 151 will not work. To be sure on exact length of replacement should have been calculated correctly. What year and model is s that? Rx1?
Robi
- Nov 19, 2021
- Saskatchewan
I measured the track by counting the windows and multiplying by the pitch and it came out to a 151That sled according to the specs should have been a 151”
It looks like you have the correct track then for the sled you have. Are you sure the rear wheels are all the way back in the slots on the rails?
Robi
- Nov 19, 2021
- Saskatchewan
I believe so. I’m pretty sure this is as far back as they go?It looks like you have the correct track then for the sled you have. Are you sure the rear wheels are all the way back in the slots on the rails?
is the front suspensions arm of the rear skid broke?
Robi
- Nov 19, 2021
- Saskatchewan
Not that I can tell looks to be fine.
Robi
- Nov 19, 2021
- Saskatchewan
So I called the Yamaha dealer in Saskatoon and he told me according to my VIN number it is a 2003 RX10-RH-R which he said shows should have a 121 track on it.
I do not believe that’s possible based on your pictures. Then I would guess someone extended it.So I called the Yamaha dealer in Saskatoon and he told me according to my VIN number it is a 2003 RX10-RH-R which he said shows should have a 121 track on it.
Measure the rail length?
