MountainMax
- Nov 21, 2004
- Churchill Falls, Labrador
- 2009 Yamaha Apex
I bought an extra wheel set to put more wheels on my 09 MTX and wondered where is the best part to put them, they are the idler wheel kit from yamaha, regular size, I also bought two sets of marginal wheels to also put in there, can someone direct me in the best places to put them, I was planning on putting one set of marginals right up front near the bend in the rails, but im unsure on the other 2 sets, especially the larger set so it won't interfere with any other parts.
GotJuice
sorry to tell ya this
Don't mean to break your heart but you can put a ton of wheels on the skid and still have problems. They need to be 1/8" bigger in diameter to actually help, yamaha's wheels are actually to small! There are other companies with spacers made or a tad bit bigger wheels to use for this very reason, (search in the Apex&Attack forums for wheel info).
MANY guys have discovered through trial and error that they actually create hot spots on the hyfax in front and behind the wheels tend to wear fast and bad. Most of us have gone to removing the wheels from the outside and running scratchers for frozen conditions. This creates a more even pressure and they wear A LOT less, sounds backwards but it's been proven time and time again! No outside wheels lasts longer. You could have bought a set of Hyperfax for 150.00 which is probably close to the cost of all those wheels. Hyperfax will last for thousands of miles with NO wheels. I run no wheels and two inner rear wheels with great success, hifax has lasted for 800 mils now and I ride a lot of hard trails for miles and miles to get to the good ground. I would return all the wheels, buy some scratchers and a set of Hyperfax and never have to worry about them again!
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
1998 VMAX 500-totalled
Can you run more than 1 set of scrathers- due to length of track?
Thxs.
David
Thxs.
David
GotJuice
scratchers
I've not heard of anyone running two sets on the rails, suppose you could but one set seems to work just fine. Some guys prefer the scratchers that mount to the inside of the front ski's , maybe run a set up there and a set on the rails if you need the extra cooling for long frozen lake runs at high speed or something?
>>WANNA4STROKE said:Can you run more than 1 set of scrathers- due to length of track?
Thxs.
David
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
how do the ice scratchers go on, where can I buy some, and how do they work when you back up? Thanks......
WANN4STROKE
- Feb 26, 2007
- Anchorage, Ak.
- 2009 Viking
2006 ApxMtn-sold
2001 MtnMax-sold
The cable style is the best for backing up but I am not sold on them- I am trying them out.
There are a variety to try out. Some mount on ski's and some on the rails. Have heard of people drilling a hole in back of skiu and putting a bolt thru- double nut it and adjust down when needed.
Hyfax wear is an issue on these beasts.. I went thru a set in 400 miles. New set I grooved the entire length. Trying that now. If it does not work- I'll try removing wheels.
David
David
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
These are supposed to flip around in a reverse situation as long as the snow is deep enough. Ski mounts.
http://www.ty4stroke.com/viewtopic.php?t=61579&
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
I don't run the Apex but my RX-1 has gone 2000miles on the current set of hyfax. I removed all the wheels and added scratchers. Here's a picture of my skid with Holtz Racing Products ice scratchers. I just hook them on the rails like pictured when not going down the hardpacked trails.
Jim
Jim
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
What about cutting down the track? i would be happy with a 1.75" track , it should help when in harder pack trails too right? there are no mountains where I live, I just wanted to buy a large sled and long track to keep my heavy #*$&@ afloat.......
tmk50
I run Hyperfax and scratchers on my Apex Mtn - that works well for the conditions I ride in.
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
can you use ice scratchers and not have to remove any wheels to mount them, and where can I buy hyperfax? i have them on my 02 mmax and never changed them since 03, bought mine at bender racing way back then
motorman
scratchers
i only got 500 kilometers on sliders with stock mountain set up,with scratchers.
i since went timbersled front and rear,removed wheels and using scratchers,and my sliders still look new after 500 kilometers(cheap 15 dollar a piece sliders)
imho the yammy wheels are overated,and the sliders are underated
MountainMax
- Nov 21, 2004
- 2009 Yamaha Apex
what is this timbersled stuff people are talking about? i never heard of them in the 2 stroke world.... (new to 4 strokes)
motorman
timbersled
http://www.timbersled.com/
i have nothing but good things to say about Allen at timbersled,and would recomend them to anyone.
I broke my rear h arm(my fault) called allen at timbersled and had a new one 200 dollars plus shipping at my door in 5 days.there suspention takes some tweaking to set up how I like it in different snow conditions but once you figure it out,it works,and works well.And you can call Allen at anytime for any questions regarding his products.
good luck D
good luck D
motorman
stock suspention
i do want to add that the stock suspention did also work well for me,my only complaint was the weight.it was a pig to get unstuck.
