lockburner2000
If anyone has any pics of them installed on there sled could you please post. Any info on installing would be a great help. Thanks
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Put them on your skis, get a Longer bolt for the ski mount and put them on the inside.
lockburner2000
I allready ordered the ones that go on the rails. Will they work or not????
APEX 06
- Apr 30, 2009
- Sheboygan, WI
lockburner2000
Do they stay Stored if your not using them? How much of a longer bolt did you get? Im sure there not a standerd size do you remember what mm they were?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
They stay on the pilot ski ok. And for the bolt I went to Fastal with the bolt and told them I need the longest one they had. I think it was 8" long.
lockburner2000
That was Fast!!! I can go there and do the same then.
I put them behind the rear smaller idler on my wifes Vector...works mint.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
vector06 said:I put them behind the rear smaller idler on my wifes Vector...works mint.
A 121" skid? Could you post up some pictures if you can?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
studdog
I found running board mounted ones that work as well or better than rail mounts and are easier to deploy. Got mine thru Royal distributing in Canada. I think Shadetree also sells them.
CaptCaper
- Jan 1, 2007
- Northern N.H.
studdog said:I found running board mounted ones that work as well or better than rail mounts and are easier to deploy. Got mine thru Royal distributing in Canada. I think Shadetree also sells them.
I saw pictures somewhere on TY for these. Can't remember were but they were awesome.
lockburner2000
CaptCaper said:studdog said:I found running board mounted ones that work as well or better than rail mounts and are easier to deploy. Got mine thru Royal distributing in Canada. I think Shadetree also sells them.
If you find those pics some where let us know i like to see them
CaptCaper
- Jan 1, 2007
- Northern N.H.
Tunnel mounted pictures http://www.ty4stroke.com/viewtopic.php? ... cc4a45dd39 also here http://www.ty4stroke.com/viewtopic.php? ... er&start=0
