Cmireau
have a 2009 yamaha Nytro turbo with the 240 kit on it. I have a cr racing tunnel and a m10 suspension and I cannot wheelie at all! Any suggestions?
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
I think your problem is the M10 suspension. This is a fully coupled suspension for great ride quality. If you want to stand your sled up on end you need an uncoupled suspension.
MERRY CHRISTMAS EVERYONE
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Nailed it!!!I think your problem is the M10 suspension. This is a fully coupled suspension for great ride quality. If you want to stand your sled up on end you need an uncoupled suspension.
VK540V
The M10 is the worst suspension for transfer ever created. It was revolutionary in the early 90’s, mind blowing even, but it’s now a 28 year old design and many OEM skids are much better. The only thing the M10 does well is ride like magic in the stutters. I had one and it was garbage in the big bumps as it couldn’t handle the big hits, it didn’t transfer, and it was hard to adjust. Falling rate skids are not what works. The M10 was amazing becuase it had 10” of rail travel during a time period of 6” travel rear skids. Now it is a boat anchor. I’d recommend swapping in a Ski-Doo rear skid that you can get a good deal on.
Climbmax
An M10 was likely installed to keep the nose down and sled parallel to the hill when serious hillclimbing was the target. They really are the bomb when it comes to vertical climbing. But take all the "fun factor" out of the sled as a daily rider. Puts all the energy on the nose of the sled which makes it a one dimensional ride. All the serious "Free Climbers" usually put an M10, CR10 or Baker Skid in their boosted 4 strokes to make them climb with efficiency. If you want to make it a play sled then I'd suggest you look at alternative. A Viper Mtx skid from 2016 would be a very decent alternative and cost effective. Light and cheap as well. If you want to see about tuning your M10 send me a pic of the distance between your rear blocks (the gap) on rear arm. Those can be tailored a bit to help with transfer. Cheers
Cmireau
Can I take the blocks out of the suspension at all? Or do I need a whole new skid?I think your problem is the M10 suspension. This is a fully coupled suspension for great ride quality. If you want to stand your sled up on end you need an uncoupled suspension.
does anybody have a stock skid out of a Nytro or viper for sale?I think your problem is the M10 suspension. This is a fully coupled suspension for great ride quality. If you want to stand your sled up on end you need an uncoupled suspension.
Cmireau
Would a timber sled skid work for wheelie?An M10 was likely installed to keep the nose down and sled parallel to the hill when serious hillclimbing was the target. They really are the bomb when it comes to vertical climbing. But take all the "fun factor" out of the sled as a daily rider. Puts all the energy on the nose of the sled which makes it a one dimensional ride. All the serious "Free Climbers" usually put an M10, CR10 or Baker Skid in their boosted 4 strokes to make them climb with efficiency. If you want to make it a play sled then I'd suggest you look at alternative. A Viper Mtx skid from 2016 would be a very decent alternative and cost effective. Light and cheap as well. If you want to see about tuning your M10 send me a pic of the distance between your rear blocks (the gap) on rear arm. Those can be tailored a bit to help with transfer. Cheers
Climbmax
Yes for sure. I had one in a Nytro MCX 270 174". Was both fun and a reasonable climber when I coupled it earlier. Super light as well. If you can find one for a reasonable price it wouldn't be a bad idea. Make sure its in good shape however, as they were light for a reason.Would a timber sled skid work for wheelie?
I also know Chad at CR has a 162 Viper skid complete he would sell. Give him a call 250-491-1836
Good luck.
Cmireau
Thanks a lot I appreciate all the help!!Yes for sure. I had one in a Nytro MCX 270 174". Was both fun and a reasonable climber when I coupled it earlier. Super light as well. If you can find one for a reasonable price it wouldn't be a bad idea. Make sure its in good shape however, as they were light for a reason.
Good luck.
VK540V
I custom cut/shaved the blocks down in mine and it helped to increase transfer. The downside is the coupling is then reduced making it easier to bottom out. I honestly thought the skid was a confused mess. Back then they offered an electric motor kit to move the position of the rest track shock fore and aft to increase/decrease bottoming resistance. They then went to air bag springs that rapidly increased in rate as the suspension compressed. This helped to offset the falling rate.Can I take the blocks out of the suspension at all? Or do I need a whole new skid?
I‘d try shaving the blocks down first as it is free and see how you like it.
- 7K
