08NitroRTX
Hi I'm asking for a friend:
Using stock drivers on a 2007 Nytro 121", what is the largest lug track we can install? He wants to add 136 rail extensions and a 136x1.75x16 wide track. Can someone please tell me if this will or will not fit? SO I guess I need to ask IF a 16"wide track fit under there too?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I've got a stretched '06 Nytro (which is the same as the '07). I'm running a 15"x136"x1.5" track. I don't know about going to a 16" wide. But I can tell you for sure that with using the stock drivers, the tallest lug you can fit will be a 1.5". If you drop to an 8 tooth driver, or remove the front cooler protectors, you might fit in something taller.
NITROMAN
ditto!
NytroYK
Little late, but I have a 15"x136"x2" Challenger under my 06 Nytro. Went down to an 8t 2.52pitch driver from whal, just to be safe and so I could run the track loose.
rx1ryda989
- Feb 7, 2007
I got a 16 inch wide 136' ripsaw in my 03 rx1, u will have to shorten the chaincase bolt in the front, shave down some rivets, and fab some smaller drop brackets, but she'll fit!!!!
