Yamacat21
Dads LTX has a very very slow leak somewhere on the chain case. Just a couple drops a day but still shouldn't have this on a new sled. Anyone else seen the same thing? Just tighten the bolts or let the dealer worry about it?
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
If it's not to hard to get to your dealer I would for sure bring it back to them! And make sure they fix it while your there!
fxnytroxtx
Guest
How many miles is on it?
Yamacat21 said:Dads LTX has a very very slow leak somewhere on the chain case. Just a couple drops a day but still shouldn't have this on a new sled. Anyone else seen the same thing? Just tighten the bolts or let the dealer worry about it?
Take it back to the dealer...unless they topped it off and spilled it...
allyammies
oh great here we go a 1100 with 7 miles on it was leaking on our club trip last year could only ride maybe 40 miles and needed to add.Better go look under the skid plate.
Yamacat21
Only three miles on it. We thought maybe they spilled some so cleaned everything up we could but now there is oil on the floor again.fxnytroxtx said:How many miles is on it?
fxnytroxtx
Guest
Yamacat21 said:Only three miles on it. We thought maybe they spilled some so cleaned everything up we could but now there is oil on the floor again.fxnytroxtx said:How many miles is on it?
I got 75 miles on mine and just checked it and it clean and dry
yikes. hope this is a isolated problem.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
mine is fine no leaks
fxnytroxtx
Guest
Cats are know for coming with loose or missing parts of the assembly line
mike g
I'd look at each bolt holding the oil tank on and make sure it isn't broken at any of the bolts
Suckur
Check your sleds from stem to stern! I can't stress this enough. These are Arctic Cats and Yamaha dealers are not used to this. My brother is a licenced mechanic and certified BRP tech. He bought a 14 Proclimb and went over it from front to back. He only found a few bolts not tightened and some broken stuff from crate damage. Mine was the same. These are not Yamahas. If you have the ability check everything you can. They are great riding sleds but some of them look like they're assembled by teenage girls. I am currently in a love/hate relationship with mine. All the sh!t that went wrong with mine (including a blown motor) was due to poor assembly. I don't want to come off like a negative Neddy, I just want everyone to be safe and enjoy their new machines.
Yamacat21
Pulled the can out and found oil on top of the case and a loose hose clamp at the bottom of the case. We will keep an eye on it but it goes back to what suckur said, check them over good. The gasket didn't tear so we will see if it reseales. Also WARNING!!! The gasket has a metal sheet in it that is very sharp, RAZOR SHARP! Be carefull taking off your exhaust.
They really need to hire a new manager to kick some #*$&@ in the qc department
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Agreed!^apexgt40 said:They really need to hire a new manager to kick some #*$&@ in the qc department
