Viper Frequently Asked Questions
cannondale27
Staff member
Moderator
Vendor
Manitowoc,WI
This is where you can find SR VIPER posts that Give ride reviews,Observations of the Prototypes,Features you would like to see and Procross problems and solutions that directly relate to the SR Viper only. These threads will be heavily policed and only way to get a post in here is if it is a clean post,to the point,on topic and helpful to the YAMAHA people who use this site. PM me or one of the mods if you think a post belongs here. Eventually this will become the FAQ threads we all have depended on. Work in progress.
NEW SLED INSPECTION/MAINTENANCE
GAUGE OPERATION VIDEOS
TECHNICAL ORIENTATION GUIDE PLEASE DOWNLOAD AND READ
2016.5/LATE BUILD ENGINE/CHASSIS CHANGES
16.5 ROD FAILURE ANALYSES BY HURRICANE
2016 DIGITAL SLED BROCHURE
2016 CHAIN-CASE LEAK
2016 xtx le REAR IDLER ISSUE
2016 141"RUBBING SOUND AT FRONT OF SKID
EASY WAY TO CHANGE YOUR OIL
LOOSE STEERING LOOSE STEERING
FUEL LINE RECALL
FUEL LINE FAILURE AT FILTER
PICS OF POTENTIAL ISSUES/FIXES
CHAIN CASE LEAK
COOLANT LEAKS
CHAIN CASE ISSUE
IDLE INCONSISTENT
CHAIN CASE/REVERSE ACTUATOR INSTALL
OIL LINES UNDER MUFFLER RUB POINTS
PRELIMINARY TORQUE SPECS
OIL SEPARATOR CLEANING
CRACKED HEADER PIPE
AIR BOX SHELF/DIVIDER CRACKING
WET/DAMAGED REAR STORAGE BAG
SLED DIES WHILE RIDING
PAINT CODES
BRAKING
BRAKING
SQUEALING NOISE
HANDLING and WEIGHT REDUCTION
SKI OPTIONS,TUNER SKI
WEIGHT LOSS
LTX SCALED/BALANCE
VIPER DIET/REVERSE DELETE
MTX HANDLEBAR RISER INSTALL
Tracks/Drivers
EXTROVERT VS INTROVERT DRIVER MEASUREMENTS AND RATIOS
TRACK CLIPS
TRACK LENGTH HOW MANY BARS ON SNOW BY PORT YAMAHA
SUSPENSION
Rear Suspension Mounting Holes
Adding 4rth wheel - DIY Video
STANDARD/DX SUSPENSION SETUP
LTX SUSPENSION SETUP
RTX SUSPENSION SETUP
XTX SUSPENSION SETUP,MORE
HYGEAR XTX SETUP
SPRING CHARTS
REAR SHOCK/ARM FAILURE
FLOAT2vs3
FLOATING FRONT ARM
RAILS
BIG BOY SETUP
REAR SUSPENSION REMOVAL REAR SHOCK SHIM SPECS
CONVERT YOUR SLED SUSPENSION TO TWO UP
STUDDING ,2
TRACK DRAG/SUSPENSION SPEED LOSS
RAIL AND TOEHOLD STIFFENERS
SMOKIN RIVETS ,MORE
VIPER CROSS SHAFT SHEARS
DRIVE TRAIN
DIY Video on Chain case Oil Change
Reverse Actuator Repair
REPLACEMENT REVERSE ACTUATOR
MPH AND GEARING CHART AND CALCULATOR
YAMAHA BELT SPECS
TECH BULLETIN REVERSE DETENT TECH BULLETIN How to step by step
BELT ,2 ,8JP BELT
CHAIN CASE
SECONDARY/JACK SHAFT
Filling the Chain Case
DRIVE/JACK SHAFT BEARING REPACKING
CHAIN CASE REMOVAL AND INSPECTION
BUSTED CHAIN CASE, WOBBLE BEARING REPLACEMENT
LOOSE DRIVESHAFT TO BRAKE SIDE BEARING FIT
JACK SHAFT AND BEARING REMOVAL WITH VIDS BY Janne339
JACK SHAFT UPGRADE AND DRIVER CHANGE
EXTROVERT VS INTROVERT DRIVERS
REVERSE ACTUATOR EXTENDED LIFE FIX and VIDEO OF INTERNAL OPERATION BY FROZEN TOWS
NEW CHAINCASE O-RING SEAL
ELECTRICAL/INJECTION
Checking you TPS
HID Bulb Reflector Mod
BAR CODE LOW VOLTAGE FIX
THE NEW 2017 FLASH UPDATE
CLEAN YOUR BATTERY CONNECTIONS BY FROZENTOWS4
WIRING DIAGRAMS
ECU PART#'S FOR EACH MODEL
CAT INJECTION
HID LIGHTING KITS
TROUBLE CODES
FUSES AND RELAYS
RELOCATING FUSE BOX
P1338 CODE
TETHER INSTALL
BATTERY NOT CHARGING
CLUTCHING
Helix # Reference Charts
POST YOUR CLUTCHING SPECS
TY TECH ALL THE CLUTCH SPECS AND MORE
MATH BEHIND CLUTCH MACHINING
HITTING REV LIMITER/MISFIRING
8DN SIZE BELT ON VIPER
CLUTCHING ON THE CHEAP
PRIMARY SHIMS MADE EASY
ULMER CLUTCH AND BELT INFO
PRIMARY CLUTCH SPRING SPECS
DO NOT ROTATE CCW when changing clutch parts
ENGINE/ PERFORMANCE
Starter Gear & One Way Clutch Inspection
Ulmer Performance Package
BOOST AND AFR GAUGE LOCATION
CHECKING OIL LEVEL
OIL CHANGE QUESTIONS
OIL CAPACITY/EASY DRAIN
OIL SEPARATOR ISSUES
POWER COMMANDER
TURBO
TURBO #2
TURBO VIPER TIPS
SMARTVALVES
HP?
HURRICANE
DYNOCHARTS
ULMER
ULMER #2
AIRBOX/DYNOCHART
EVOLUTION POWERSPORTS ECU REFLASH AND EXHAUST
ENGINE OIL LIGHT ON
OIL TANK UPGRADE
STINGRAY AIRBOX MOD VERSION 2
DYNOJET PCV STUTTER INSTALL by Studroes
VALVE CHECK AND ADJUSTMENT
EXHAUST
EXHAUST
EXHAUST GASKET
EXHAUST CAN SPECS BY THE NUMBERS
OSP
SLP
SKINZ
MBRP
EXCELL
BODY
PHOTOSHOP PANEL SWAP
Viper to Sidewinder Headlight Swap
HOOD REMOVAL
SEAT REMOVAL BOLT OPTIONS
BLEED YAMAHAS SKID MOD AND OIL CHANGE ACCESS
ADDING VENTS TO ENGINE COMPARTMENT
FELT SOUND/HEAT REPLACEMENT ON PANELS
ACCESSORIES
Portable Jump Packs
HEATED SHIELD WIRE INSTALL
HID INSTALL PROCEDURE
GRAPHICS
ALL KINDS
ACCESORIES AND MODS UNDER $100
CROSSTOUR/MID HEIGHT WINGED WINDSHIELD INSTALL PICS
YAMAHA ACCESSORIES AND CATALOG
LED PARKING LIGHT INSTALL
TUNNEL BAGS
HANDGUARDS
HOW TO VIDEOS
How to Change your Belt!
BELT REMOVAL
STINGRAY AIRBOX MOD BY STUDROES
FOX FLOAT 2,3 and EVOL X SETUP VIDEOS
CLEANING/FREEING UP YOUR CLUTCHES BY NOS PRO
SETTING SPRING WRAP ON SECONDARY ULMER VIDS
HOOD REMOVAL BY STUDROES
PRIMARY CLUTCH COVER INSTALL BY NOS PRO
EXHAUST REMOVAL BY STUDROES
CLUTCH KIT INSTALL AND OTHER GREAT CLUTCHING BASICS BY NOS PRO
VIDEOS
YZM450 TESTRIDE
Viper
YAMAHAS VIPER REVIEW VIDEO
Chris Reid/SnowTrax
DEEP FRZ
KINGER
Guage Operation/Viper Exhaust Note
MANUALS/SPECS
VIPER TORQUE SPECS
VIPER SPECS
LATEST SPECS
FACTORY SPEC SHEETS
PARTNUMBER CODE
VIPER OWNERS REVIEWS
LTX SE by APEXGT40
XTX by Ryan466
LTX-vs-XF7000 by Studroes144,2 Belt Temps and Race
MOUNTAIN VIPER by HYFLYER
RIDE REVIEWS PROTOTYPES
MAIM
DeepFrz
YAMAHAS
DeerHunter/BenApexgt
AK Yammy
TY VIPER BUILDS AND UPDATES
2014 Viper Ulmer Tuned
2014 Viper Ulmer Tuned Stage2
