neonphil
I have been running my sled over 230 degrees during testing. To put an end to that I added a radiator from an ATV . I drove my sled for about 15 minutes and it never went over 207 degrees. The total weight of the cover,radiator and fan was 5 1/2 lb.
- Apr 14, 2003
- Hessel, Michigan
That would help big time on the asphalt! PM me with the atv info you got that from.
Phil, I can't keep my sled that clean, and I don't even run grass.
Man, that sled hauls but!!!
Indy
What a genius! Why the foil on the radiator? You must tell us the info you tease. What part numbers? What cost? Who did your cover and how much? Do you have the dimensions? Power source? Would it fit in the front in place of the tool box?
rupprider
AH HA, an active down force device ala Chaparal. (Jim Hall) LOL
Auskins
wicked idea...did u race with it yet?
i say u'll make up for the 5 pounds no trouble with the added performance from running cooler
I'll have to look into that I have a radiater and fan from my quad I parted out it look's the same size.
neonphil
NOS-PRO said:That would help big time on the asphalt! PM me with the atv info you got that from.
I purchased it off EBay and won the auction paying $102.
In the description it only states YAMAHA YFZ RADIATOR.
This would be perfect for asphalt!
neonphil
Indy said:What a genius! Why the foil on the radiator? You must tell us the info you tease. What part numbers? What cost? Who did your cover and how much? Do you have the dimensions? Power source? Would it fit in the front in place of the tool box?
When I designed the cover, my main goal was to make it as "stock" looking as possible. Air is drawn through the back of the cover and discharges over the snowflap. The foil keeps the air from recirculating through the radiator.
I made a template out of posterboard and transferred it to a piece of .065 aluminum.
The fan costs $71.99
http://www.offroadwarehouse.com/Store_ViewProdDetail.asp?ProdID=8539
Radiator: EBAY auction for $102.
Sheet of aluminum: $20.
This would not fit in place of the tool box. Although, you probably could find a small enough radiator that would fit.
neonphil
Auskins said:wicked idea...did u race with it yet?
At the last race, when I returned back to the pits after making my pass, my water temp was 140 degrees. Normally it would be above 220.
LooseCannon
Very nice work, looks super!
Blue shadow
Looks good neonphil.
- Apr 14, 2003
- Hessel, Michigan
Thanks Phil, keep 'er rockin!
Sweet dude... I love projects like these. Great idea and execution... not much money spent... which leaves it in place for other things.
I have an 03 shorty runnin 210 degrees all the time. So today I checked the anti freeze and sure enough it was 100% anti freeze. So I diluted it quite a bit and added water wetter. After an hour of adding and subtracting and adding the WW it still ran a religous 210. Is this okay. I see alot of guys say they run 170-190.
