4bangpower
Kevin,
Does Yamaha offer stiffer spring options for the Mono Shock II RA on the '10 RS Vector GT? Thanks in advance.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
The Mono-Shock II RA uses the same spring options as the original Mono-Shock suspension. The most popular stiffer spring to put on would be the 6.5Kg spring which is part number 8FU-47489-10-00. The stock spring is a 4.5Kg rated spring.
