Parts:
8ES-12210-01-00..........(1) TENSIONER ASSY (blue dot)
4FM-12213-00-00..........(1) GASKET, TENSIOER
93210-26006-00............(1) O-RING, VALVE COVER COOLANT PIPE (Recommended)
8FA-14623-00-00...........(3) GASKET, EXHAUST DONUTS (Recommended)
50/50 AUTOMOTIVE COOLANT (Optional)
1) remove side panels
2) remove seat and gas tank (gas tank cover and handlebars can be moved off to the side)
3) unbolt exhaust system and slide back a few inches (4 muffler bolts, 2 hanger bolts under platic plugs and 3 manifold clamps)
http://www.ty4stroke.com/viewtopic.php?t=90978
4) remove steering column (unbolt the 2 bearing holders and swing it out of the way)
5) remove secondary clutch (don't lose shims on the back side of clutch)
6) remove air breather/ battery/ battery try and then loosen the 2 front engine mount bolts
7) drain the oil tank and remove it, drain the coolant by removing the lower cooler hose
8) remove the upper coolant pipe on top of the valve cover then remove the valve cover (The tube is held in by a cap screw and seals with an o-ring. Clear the head of the cap screw of any debris then use a 6mm allen socket to remove it. I've had to tap on the allen socket with a hammer to loosen the screw.)
9) set the #3 cylinder on TDC. To do this remove the inspection plugs in the stator cover and rotate the engine CW until you pass a single "I" stopping at the "II" mark. The #3 cam lobes should be pointing down and away from each other (7 and 5 o'clock, #3 lobes are closest to the cam gears). If they are not rotate the engine one revolution CW (never rotate CCW). The cam timing marks should also be aligned at this point (exhaust ---> ----- intake).
10) use tie straps or wire ties to secure the timing chain to each gear. Cover the valve area with a rag to prevent anything from falling into the motor.
11) unbolt the long rear engine mount bolt and remove it. Remove the engine spacer with the special socket by turning it CW. The engine will have to be rocked up from the rear to get it out. (be careful not to damage the spacer or aluminum side plate threads)
12) with the engine rocked up unbolt the old (orange dot) tensioner and remove it. Clean the gasket area and install the new gasket and (blue dot) tensioner.
13) with the new tensioner bolted in pull the small tab to release it then install the new end plug. If there is slack in the chain between cam gears use a 10mm wrench on one of the rear cam gear bolts and rotate CCW just enough to take up the slack before releasing the tensioner. remove the ties on the cam, recheck all the timing marks then rotate the engine CW a few revolution then recheck the marks again at TDC. (when the new tensioner is released it doesn't always take all the slack out of the chain until the engine is rotated. I've had the chain jump the intake gear because of this so I position tie straps on the gear so that the engine can be rotated with the straps on. I reposition the tie straps several times as need until I make one revolution of the crank)
14) if all is OK put it back together.
Note: If you're replacing the exhaust donuts install them on the flex pipes before lower the engine.
Removing and reinstalling the lower cam tensioner bolt is difficult. A flexible 1/4" socket driver with a 8mm socket and a 1/4" drive 90 degree socket wrench helps. A magnet will also help getting the bolts in and out without dropping them. The special socket for removing the engine spacer was made from a 1/4" deep well 13mm socket. See special tools picture below.
http://s589.photobucket.com/albums/ss337/grizztracks/RS Yamaha Cam Chain Tensioner/
