Sounds like the plugs are fouled
Warp
I put new plugs in it toSounds like the plugs are fouled
earthling
Have you checked the voltage regulator? The popping however I would think comes from the pickup coil, not the stator itself.
Did you use an OEM stator or aftermarket.
Warp
After market, RM stator
RobX-1
- Coldwater, OH
Previously, you mentioned the pickup sensor was showing zero ohms but then stated you replaced the stator. Was that just the stator or did it include the pickup sensor as well? When I replaced my stator, I opted for OEM so both were included and not familiar with the RM stator but do believe you could purchase the two separately (ie, stator and sensor) whereas OEM you could not. I also recall an issue when replacing the sensor with an RM that sometimes guys had to swap wires.
Sometimes the pickup coils are polarity sensitive so try switching the wires at the plug.After market, RM stator
Warp
I replaced the stator and pick up coil last week and code 12 is gone but machine still won’t start. I did a compressor test WOT and I got cylinder 1 was 80lbs, 2 was 170, 3 was 160 and 4 was 150. Could this be a timing issue?? Also can hear compression coming out the air intake. Anyone got a similar problem?
sounding like a stuck valve or it needs valve shims checked.
