TPC
- Feb 27, 2023
- Newfoundland
- 2013 Venture RS 1000 4 Stroke
My 2103 Yamaha Venture RS 1000 4 stroke won`t stay going without throttle and is exhausting black smoke.
theCATman
Start with a fresh set of plugs. Sounds like one or more is wet and/or carbon fouled. That's the sooty, rich exhaust smoke.
Have you been starting it and shutting it off before it gets up to operating temp??
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
If its the carb version, perhaps the choke is stuck on.
TPC
- Feb 27, 2023
- Newfoundland
It`s has been warmed up and no lights on before use...Not sure what you mean by shutting it off before being warmed up...How do you change the sparkplugs?...This is my first 4 stroke.Start with a fresh set of plugs. Sounds like one or more is wet and/or carbon fouled. That's the sooty, rich exhaust smoke.
TPC
- Feb 27, 2023
- Newfoundland
No choke on this modelIf its the carb version, perhaps the choke is stuck on.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
My first question is fuel, what gas is in it? Is this old fuel?ethanol or non ethanol? As far as starting he was talking about people who will start the sled& run it a minute & shut it off, then 2 weeks later they do the same thing, this will sometimes cause spark plug fouling, please tell us more about the machine, how many miles? How is it stored? Is this a new machine for you etc usually if the plugs are fouled you can tell immediately as the engine runs rough & stumbles &doesn’t sound smoothIt`s has been warmed up and no lights on before use...Not sure what you mean by shutting it off before being warmed up...How do you change the sparkplugs?...This is my first 4 stroke.
- 7K
