Sidewinder900
- Jan 16, 2022
- Manitoba
- 2018 Yamaha Sidewinder LTX, 1997 Arctic Cat Cougar 580cc
- Winnipeg
- Gosselinconsulting.com
We had seld in the dealer for a pre-season for all oils and filters changed, amd when I picked it up, it is now leaking oil to belly pan and on floor under sled.
Anyone Have this issue and know where to start looking?
Todd Beenen
It could be residual from the oil change, wipe all oil off, make sure ,if you can check drain plugs. Wipe them off good, then re check them
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I would still contact the dealer and tell them. When I got my sw years back from Excell, they explained about residual oil and drilled a small hole (with my permission) in the low spot of the bellypan to drain any excess.We had seld in the dealer for a pre-season for all oils and filters changed, amd when I picked it up, it is now leaking oil to belly pan and on floor under sled.
RAMSOMAIR
If you drain the oil correctly (as a dealer should do) there shouldn't be any residual oil anywhere. If they did spill some, they should have whipped it up and then sprayed a bit of engine cleaner in the engine bay and hosed it out. This is why nothing I own ever goes back to the dealer.
Points taken, however, if Yamaha and Cat had designed things better, it wouldn't be so onerous to change the oil on these things.If you drain the oil correctly (as a dealer should do) there shouldn't be any residual oil anywhere. If they did spill some, they should have whipped it up and then sprayed a bit of engine cleaner in the engine bay and hosed it out. This is why nothing I own ever goes back to the dealer.
RAMSOMAIR
But the dealer should be able to do it better and at very least clean up their mess grrrrr.
Yes, good idea to wipe things down, then hopefully it can stay overnight at the dealer for any final drips.But the dealer should be able to do it better and at very least clean up their mess grrrrr.
Sidewinder900
- Jan 16, 2022
- Manitoba
- Winnipeg
Drain plug was loose from dealer. Tightened that.
Found now they didn't even check any hose clamps or anything amd it's dripping antifreeze. Never going back there.
Todd Beenen
Sheesh. No doubt go over all the clamps good, which plug was leaking?
Never good when the drain plug is left loose.Drain plug was loose from dealer. Tightened that.
Todd Beenen
To the OP. Buy a service manual, if possible do the oil change yourself, it’s really not that bad of a job
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Become a VIP member and the Admins will send you a shop manual. Well worth the investment.To the OP. Buy a service manual, if possible do the oil change yourself, it’s really not that bad of a job
Sidewinder900
- Jan 16, 2022
- Manitoba
- Winnipeg
I have fixed the problem. The dealership didn't tighten the drain plug, as well as antifreeze lines. Smy Viper is
perfect now after I went through the work they did.
How do I become a VIP member?
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Go to the menu and click on Ty info, select VIP and follow instructions
RobX-1
- Coldwater, OH
