rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Do you need to have a bov for the stock muffler 270 flashes from hurricane or td
justinator
Its a good idea, tunes from either of these vendors in that hp range are gonna be 16-17psi+ and thats where stock bov is known to leak.......sometimes at much less.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Not needed unless yours is leaking.
NYTurbo
Seen them leak under 15 psi.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I don’t have one and I see 17psi on my gauge. I have the Hurricane 270sm tune.
snowdust
Consensus will be yes as many leak at the higher boost levels. I have a turbosmart I'd sell if you are interested. I changed and went with one from Tommcat so I could hear it more when riding.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
You went with quality ! Did the same .. Turbosmart makes some quality BOV. You will pay for a good one.. The china junk one for 120 is a waste of time. Do yourself a favor and spend a couple hundred for qualityConsensus will be yes as many leak at the higher boost levels. I have a turbosmart I'd sell if you are interested. I changed and went with one from Tommcat so I could hear it more when riding.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
If it’s no leaking why? Or you have lots of extra money to buy one, there like $250-$300 just to hear sssshhhhhhhh.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Not speaking about any sound coming from it.. The cheap china one leaks.. We will hear its fine and you need to tighten it and or it a slight engineering flaw, etc.. Bottom line its not a quality BOV. For a good aftermarket BOV you will pay a couple hundred.. The stock one works fine for some and so do other aftermarket ones. pick your poison.. And IF it doesn't leak its fine!.. How many guys even no if it leaks?
