KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
I would like to know if a reverse angle helix helps with spooling turbo even quicker,why are they a bad thing with the quicker spooling tunes? I run one and everyone I let take sled for a ride says it’s the snappiest 4 stroke sled they have ever ridden. As close to a two stroke for throttle response as I can make it. Now if somebody tells me the progressive helix will make it even better throttle response wise, then my sled will be 2 stroke-esque!!!!!!
For quick E.T.s drag racing, "snap" does not make a sled fast, actually quite the opposite. I always get a kick out of the guys who want them to wing right up. The quickest 60 foots are when they are boarder line to bogging and pulling the engine to its knees and shifting aggressively and not revving up right away to peak HP RPM.
On the other hand, if you are doing rolling starts with good traction, peak HP RPM will accelerate quicker than a sled that is not at peak HP RPM. Its all traction based, both track to the ground and belt to the clutches.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
I agree 100% with LUG it to get good et’s but I had to be honest with myself years ago about what I do most, drag or trail ride. I trail ride more so always looking for the corner to corner stuff. That being said, I did purchase a 39/35 from Justinator to try! Lol…..guess I will be doing more testing again and again and again…..gotta love clutching! Oh, and thank god for being retired!
Turboflash
- Mar 18, 2019
- Southern MN
My Dragy testing this past winter showed this to be true. 2 secs faster in 330 from a dig with more aggressive up shift vs reverse angle. From a 15 mph roll, reverse angle reved quicker but was really about same et to 330. Turbos like load and this 998 system has very little lag so IMO it doesn't need clutching that allows engine to "free rev" down low.For quick E.T.s drag racing, "snap" does not make a sled fast, actually quite the opposite. I always get a kick out of the guys who want them to wing right up. The quickest 60 foots are when they are boarder line to bogging and pulling the engine to its knees and shifting aggressively and not revving up right away to peak HP RPM.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
..I prefer the straight cut stuff, but IF i was going to play around I would try something around the one you got. Maybe even a 40/36I did purchase a 39/35
Fleecer
- Jun 13, 2014
- 2019 SRX
I think it depends on the tune. My Hurricane sled loved a big helix down low.
NYTurbo
2 secs in 330 is bus lengthsMy Dragy testing this past winter showed this to be true. 2 secs faster in 330 from a dig with more aggressive up shift vs reverse angle. From a 15 mph roll, reverse angle reved quicker but was really about same et to 330. Turbos like load and this 998 system has very little lag so IMO it doesn't need clutching that allows engine to "free rev" down low.
Turboflash
- Mar 18, 2019
- Southern MN
Agree completely. That's the setup I think D&D is still selling for "trail performance". When they first sold me this (years ago), I questioned them about this very thing. Of course they said it would work. Reverse angle setup cannot shift up nearly fast enough on usual trail snow conditions. It would almost always bang rev limiter until it hooked. Gets worse with big HP.2 secs in 330 is bus lengths
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
What helix do you guys recommend with hurricane bundle ss pm using xs825 belt. Right now using heavy hitter weights with their orange springs and 33-35. I was told by another member to try ygy or ywy Yamaha spring in the primary. Was thinking trying b/o at 90 in the secondary since I have one in the wrapper still. I was thinking of getting a dalton 38 but only want to buy one and be done. Thanks
Fords4life
- Dec 7, 2021
- South Dakota
Im running hurricane ss pm 240hp 270 hp with heavy hitters with tp orange primary, ulmer racing 39/35 helix with epi purple spring wraped 9&1 as per allen, works realy well, realy perky for trail riding, good backshift, good mph, realy nice setup, good belt life also.What helix do you guys recommend with hurricane bundle using xs825 belt. Right now using heavy hitter weights with their orange springs and 33-35. I was told by another member to try ygy or wyw Yamaha spring in the primary. Was thinking trying b/o at 90 since I have one in the wrapper still. I was thinking off getting a dalton 38 but only want to buy one and be done. Thanks
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
That is a helix I would like to try.39/35 helix with epi purple spring wraped 9&1
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
We used to run 60/40 helix in the old Tcats with a Bearcat secondary. They liked being lugged off the line with less angle on top.
The 1100 does as well but not with a 60/40. LOL
Looking forward to sorting out my 22' Tcat this fall. Lots of great ideas from all you guys.
