Nosey
Would you see a problem running Polaris weights with the adopter kit in my sidewinder I want to heavy my weights up a little and out of ease of getting the parts my dealer suggested using Polaris weights with the adopter kit I am now wondering if its the safe way of doing it.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I would never even consider this unless it got me out of the woods on a break down.
Get a new dealer
Get a new dealer
Nosey
Problem is kinda hard to come by in these partsI would never even consider this unless it got me out of the woods on a break down.
Get a new dealer
Fleecer
- Jun 13, 2014
- 2019 SRX
Dalton weights have the same shift profile as Polaris weights....and they are adjustable. You won't save any money buying sets of Polaris weights in 2 gram increments till you get it right.
Polaris weights might work in stock winder, but once tuned they won't have enough tip weight imo.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I got two sets of stock weights from 17 and 22 sidewinder.. You need a set?Problem is kinda hard to come by in these parts
Nosey
No thank youI got two sets of stock weights from 17 and 22 sidewinder.. You need a set?
I was talking about the dealer not the weights
Nosey
Guess I will just quit being a cheap #*$&@ and by the daltons
Thing is they have the parts sitting there and I was going to try it for my next run
I am banging on the rev limiter now when I pin it out the hole
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Have you considered running the XS belt ? These belts are "sticky' and will drop your RPMGuess I will just quit being a cheap #*$&@ and by the daltons
Nosey
Nope never heard of itHave you considered running the XS belt ? These belts are "sticky' and will drop your RPM
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Plenty of guys running them on this site.. If your over revving 400-500 rpm run the XS 825 belt. Its a good belt that allows less weight to be run. I find them to create less belt dust also. Proven to be very durable and thousands of miles on these belts with tuned sleds. usually around 100 bucksNope never heard of it
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Just simply running the XS 825 belt COULD solve this issue. Matter fact if you leave everything the way you have it now and just run the XS belt you will probably stay off the limiterI am banging on the rev limiter now when I pin it out the hole
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I have used the XS825 belt to pull down RPM's on a couple of sleds now. Seems to make them a little snappier down low also.
number1kyster
Same here. I'm running Max Spool 16 with stock weights and an X2825 belt. It revs 9,000 and the belt has been more durable as well.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I’d go thunder products clutching but daltons are a common weight used also. All of them readily available. The xs825 belt is option but at same time will still need dialing in I am sure so weights will also be beneficial and if you want to tune later on you’re ready.
