drag123
Can you please make a suggeston on my drug & fly setup 08 nytro rtx shoulder4.7 center 5.2 tip 0 overdrive 3.2 . It engages around 4000 rpm. The problem i find is that when i come to sharp corner it hits too hard and lifts the inside sky. Can i adjust it so it comes on a litle smoother. Tanks a lot. steve
Turk
Tech Advisor
Add another washer to arm or drop rollers to 14.5 mm.
drag123
Thanks Turk but to clearafy put a washer on shoulded or overdrive?Turk said:Add another washer to arm or drop rollers to 14.5 mm.
dirkdiggler
Suspended
drag123 said:Thanks Turk but to clearafy put a washer on shoulded or overdrive?Turk said:Add another washer to arm or drop rollers to 14.5 mm.
Adding weight to the heel lowers engagement. 14.5mm Rollers increases the force of the weight which brings RPM's down as well.
**sj**
yep...adding a washer drops engagement about 100 rpms and also can lower the top end by 100 rpms..
- 146K
